New Plugs, Coils & Injectors -Stills misses HELP
Just bought a 1998 Navigator 5.4L 16 valve - 115k miles.....Central Florida
Here's the history:
1) Ran great for 2 weeks then went up a few hills in north florida and started missing/bucking
2) Changed plugs (8 new Motorcrafts), 8 new COPs and 8 rebuilt injectors (at 115K miles I thought these things were due for a change anyway)
Ran great for 5 miles city test run, parked the Navigator and went for ride 4 hours later, ran worse than day 1 - like it is running on 6-7 cylinders.
3) Checked codes - got P0356 "Fault in ignition" COP #6. Changed #6 COP with old COP and still running on 6-7 cyl. Also noticed exhaust smells like rotten eggs, was not smelling like this before.
4) checked for vaccuum leaks with can of TB cleaner - found none.
5) Also noticed the EVR - (EGR regulator) makes funky noise when engine is stopped (like whining pipes in an old house).
Drove again for 10 miles to force engine to throw code - no results.
Could this be a plugged cat? Bad EGR? Bad COPs?
Anyone have similar issues?
Here's the history:
More Details
Guys,
Here's a few more details:
Filled up tank with 87 octane 1 week ago, thought maybe I got bad gas so I did the most inexpensive thing and put 1 bottle of alcohol into tank so that if there is water in tank it would mix with alcolhol and burn out. Also, partially cleaned throttle body when I changed the plugs/cops/injectors (today). 3 weeks ago when I bought the Nav, I changed oil, tranny fluid and new fuel filter.
Here's the history:
Here's the history:
(2) Never mind, I see you changed your fuel filter in your 2nd post.
(3)You need to check your fuel pressure at the schrader valve on you fuel rail. Normally I could give you the spec. but I just looked for my Haynes manual and can't find it. (we have the same engine & year)
Go through these steps 1st and let us know what happens.
TJKinCNY
Right! Or the rockers fell off, - that happens as well, check rockers first after it fails a compression test.
I pulled out the low voltage connectors on the COPs one-by-one and found #7 was not firing. I swapped out #7 COP and it is running much better. The engine don't sound quite right to me. Do the 5.4s normally sound and run like they have a very very slight miss to them? Maybe it's the natural sound to these motors and I need to get used to it. I have a 2000 F-150 4.2 V6 and it runs and sounds like a perfect engine. There is no miss or hesitation right now but will drive a few days to see if anything changes. Thanks for the great suggestions and posts. I will update this post if the problem returns. I was unaware that there is a valve guide and/or rocker problem with these engines, thanks for the insight.
My EVR (evap regulator) I think it's called, sits on the right side of the of the throttle body (when u face motor), it's black and about the size of a pill bottle. Every time I turn off the 5.4 the EVR makes a moaning-gurggling sound. Is this normal or is this my culprit? I've read a lot of posts about the DPFE (the box that has 2 hoses going to the EGR exhaust tube) going bad. Could the DPFE be my problem? BTW, I do not get any codes.
DPFE is fine.
Told you what to do - don't ignore.
