Throwing Codes
Old Jan 15, 2009 | 07:44 AM
poolboy1191's Avatar
Exclamation Throwing Codes
This week my truck has throw 2 codes at me at the same time.
P0171 and P0174
It tells me that it's bank one and bank 2.
What could be the problem? Vaccume leak?
Old Jan 15, 2009 | 08:54 AM
projectSHO89's Avatar
Those are probably the most-discussed codes on this board.
Plug them into the SEARCH tool for dozens (if not hundreds) of previous discussions.
Even a tiny bit of homework helps....
Steve
Old Jan 15, 2009 | 09:02 AM
tjk_in_cny's Avatar
[QUOTE=poolboy1191;3535348]This week my truck has throw 2 codes at me at the same time.
P0171 and P0174
It tells me that it's bank one and bank 2. Both banks running lean
What could be the problem? Vaccume leak? That is one possible problem.[/QUOTE]
I went through this same problem a year ago.
Your best bet to save yourself some time is to use the search feature on this site and type in "code p0171 and p0174".
This subject has been covered extensively and you will find your answers during your search. I'm not trying to be lazy, but I assure you,
your answer('s) will be found during your search. Evey possible solution has been discussed previously. After you do your research and you perform the checks, repair proceedure's etc and you still have a problem, write back and we can walk you through some further steps if need be. Just let us know what you have done up to that point.
Good Luck,
TJKinCNY
Old Jan 15, 2009 | 09:03 AM
tjk_in_cny's Avatar
Steve
WE WERE PROBABLY TYPING AT THE SAME TIME, WELL DONE
Old Jan 15, 2009 | 09:23 AM
jbrew's Avatar
Search
Yea , me too. - Damn I'm slow before coffee
Old Jan 15, 2009 | 09:39 AM
tjk_in_cny's Avatar
Originally Posted by jbrew
Search
I am slow drinking my 1st cup !!
Old Jan 15, 2009 | 09:41 AM
tjk_in_cny's Avatar
Interesting article when I googled "P0171 code suggested fixes"
So your car's CEL (Check Engine Light) is on and you had the codes scanned at a local parts store. Your car has either a P0171, P0174 lean fault code or both stored in the computer, these codes are based on Oxygen Sensor (O-2) readings. A lean code or codes indicate that there's too much oxygen in the exhaust. Remember parts stores have employees that have good intentions but they may not have the experience necessary to interpret what the trouble codes really mean. These codes are based on oxygen measurements in the exhaust. A common mistake with lean codes is to replace the oxygen sensors. This could be a very expensive mistake that will not fix the problem. Especially if both codes are present, because the chance of both O-2 sensors failing at the same time is very unlikely.
Most likely the cause is a vacuum leak. A vacuum leak can be caused from a vacuum hose, intake gasket or maybe even a leak in the air intake hose from the MAF (Mass Air Flow Sensor). Listen for a hissing sound that may lead you to the source of the problem. Some technicians will use a propane bottle with a hose attachment to help pinpoint vacuum leaks. With today's computers it's not quite as easy to check for vacuum leaks this way because the ECU (Electronic Control Unit) will compensate quickly for the added fuel and a change in idle is harder to notice. Oxygen sensor readings can be monitored with a scan tool while checking for leaks with propane, by looking for increased readings when enriching the mixture. Another way technicians can check for vacuum leaks is with a smoke test. By introducing smoke into a vacuum hose on the engine, the leak will be revealed when the smoke escapes from the problem area.
Aftermarket air filters that use oil on the element can sometimes damage the MAF. Over oiling the air filter may allow some excess to get on the MAF sensor wire or element. This can alter the reading, fooling the ECU into seeing more or less air flow therefore changing the air/fuel mixture incorrectly. I once worked on a car that would not start that had a problem with a MAF. When looking at the wire in the MAF, there was a burned piece of trash that made it's way past the air filter. After cleaning the sensor the car ran perfectly. The ash that was on the MAF sensor wire was altering the reading by enriching the mixture so much that the car could not run. After talking with the customer, he said the air filter was just changed. This was obviously when some trash got into the air intake hose that settled on the hot wire of the MAF.
Fuel Pressure could also cause a lean condition. If the fuel filter is clogged or the fuel pump pressure is low, there could be higher level of oxygen in the exhaust also. Most of the time though, the ECU will compensate for the reduced fuel volume. So this is one of the least likely causes of a lean code.
About the Author. Hi I'm Dennis Bandy, thanks for reading. I've been an ASE Master Auto Technician for over 20 years and have also sold professional auto tools since 2005. I am in a unique position to help readers with automotive repair related topics since I've had personal hands on experience with many auto repairs and automotive specialty tools. This is not a hobby for me, this is my business. Your feedback is really appreciated, if you thought this article was helpful or informative, please rate it below (thank you in advance).
Half the battle when it comes to auto repair is having the right tools, that's why we have supplied name-brand automotive tools (like OTC, Makita, Ingersoll), shop supplies and automotive shop equipment at discount prices, at DenLors Tools since 2005, many readers put us on their favorites list and visit our site when auto specialty tool needs arise, we hope you do the same.
Article Source: http://EzineArticles.com/?expert=Dennis_Bandy
Old Jan 15, 2009 | 09:44 AM
jbrew's Avatar
Oh no - he's googling again
Old Jan 15, 2009 | 09:51 AM
tjk_in_cny's Avatar
Congratulations Brew, you have succeeded in giving my morning and possibly my daily laugh again.
Laughed out loud (real loud) this time.
Old Jan 15, 2009 | 10:16 AM
jbrew's Avatar
Yea , I broke that habbit after getting busted. :o
