Fuel Pump not starting
I have a 96 f150 extended cab, when i try to start the truck the fuel pump won't come on at all. I am trying to figure out what is causing it I checked the fuses and it does not appear any are bad. I have no idea how to check if the relays are faulty and am looking for some advice on how to figure that out or if i am missing something totally. Also do not have the owners manual for the truck and cannot find a diagram online for the truck.
for my 93, relay number 2 is the fuel pump relay. the horn is number 3. swap them to see if its the relay. its probably the pump. does it have 2 tanks? if so switch the tank and see if the other pump works.
