PROBLEM with a engine swap
Old Jan 10, 2009 | 08:40 PM
Beastly94's Avatar
Ok here it goes i have a 1994 ford f150 with a 5.0l with Maf sensor and it has a serious ticking problem, a serious losss of compression, and my front crankseal is past smoked. but heres the problem i found a donor truck a 1990 ford f150 with a 5.0l WITHOUT Maf now will that work or do i have to do something fancy for the 1990 engine to work... Any input is greatly apritiated
Thank You
Justin
Old Jan 10, 2009 | 08:56 PM
Matts ford's Avatar
it will bolt right in. theres no changes needed.
Old Jan 10, 2009 | 09:02 PM
Beastly94's Avatar
im sure it will bolt in but what about the computer and mass air flow sensor will it make the engine run rough or can i take the maf right out of the truck
Old Jan 10, 2009 | 09:06 PM
Matts ford's Avatar
the only difference is the sensor. a the maf sensor is on the air induction tubes where a map sensor is on the firewall but you dont need the map. just put your induction tubes on and its the exact same thing. just use all the stuff on your old engine.
Old Jan 10, 2009 | 09:10 PM
Beastly94's Avatar
alrighty will do thanks but i have one more question...its got 51,000 original miles and i wanna boost her up a little bit would bigger injectors say off a 302 H.O work or what would work best to get a little bit more umph.. for cheap?
Old Jan 10, 2009 | 09:29 PM
Matts ford's Avatar
bigger injectors wont really do anything unless you need the extra fuel. a cam makes a pretty good difference. my truck has a bigger cam and i felt a pretty good difference. and i was also able to pull off just under 24mpg highway doing the speed limit with the cam and cai(mines speed density not MAF). thats about it that'll make a noticeable difference for cheap. then theres magnaflow mufflers, gears, long tube headers. flowmasters are known to restrict power.
Old Jan 10, 2009 | 09:44 PM
Beastly94's Avatar
I was deff. aiming on long tube headers and i already have a flowmaster super 44.. out of curiosity what did you use for a cam and i was also wondering on intake system. (Intake, throttle body, air intake?) Sorry for all the questions
Old Jan 10, 2009 | 10:05 PM
Matts ford's Avatar
i saw you had a super 44. they sound better than magnaflow but they take performance away where magnaflow gives better performance than stock.
i dont remember the cam specs off the top of my head but its nothing serious just a mild cam. i'm in NC for school and my spec sheets in my toolbox back in MD. a cold air intake wont work on your truck because it is mass air flow. there is nowhere to put the sensor on the intake unless you rig it up somehow. but you can get some pvc pipe and a K&N or whatever brand air filter for it and try to make your own for cheaper.
intake-i'm thinking about getting this edelbroch intake for mine one day http://store.summitracing.com/partde...5&autoview=sku
throttle body- i dont know how much of a hp and torque difference it'll make for our trucks but i'm sure it'll help with throttle response.
cold air intake- you'll have to make your own because theres no place for the maf sensor to go in the aftermarket intake unless you rig it up a little bit.
Old Jan 10, 2009 | 10:10 PM
Beastly94's Avatar
yea i saw the same intake just out of my price range lol you wouldnt happened to have a pic of ur truck would you and thanks for all the help ur giving me
Old Jan 10, 2009 | 10:18 PM
Matts ford's Avatar
no problem
Old Jan 10, 2009 | 10:28 PM
Beastly94's Avatar
Shes alittle ruff but heres a pic of my truck
Old Jan 10, 2009 | 10:39 PM
Matts ford's Avatar
picture didnt show up
Old Jan 10, 2009 | 10:48 PM
Beastly94's Avatar
http://viewmorepics.myspace.com/inde...ageID=49289969
try this
Old Jan 10, 2009 | 10:51 PM
Matts ford's Avatar
thats a good lookin truck. body appears to be in good shape except the front bumper
Old Jan 10, 2009 | 10:56 PM
Beastly94's Avatar
its got some bad rust in the box and the bumper relocation brackets need to be adjusted ...
