- oil pickup tube hitting??
- Sluggish at Initial Throttle.
- Tps Mod, Worth The Trouble??
- did I miss anything on the airbox mod?
- Engine missing at 40 mph
- any idea what 0-60 is for.........
- 4.2 vs. 4.6 vs. 5.4 engines
- 2 chamber?
- Ready to install electric fan, but which one?
- Throttle Body Change...Bad Idle
- sorry, dont click here
- race: Chevy 5.3 vs. Ford 5.4
- To pay or not to pay...that is my question.
- Amsoil Dual Filter
- HELP!! Where Can I Buy "SWING-OUT WINDOWS" for my '95 Extended Cab??!!
- Inline 6 turbo charger
- calling sundog7
- Damn...this can not be good.....
- VERY close to 9.99
- 87-92 Octane
- Fuel Rail Noise?
- New V-6 Diesel for F-150 / Expedition
- Customer Satisfaction Program 01B83/Radiator Replacement
- Looking for a little knowledge!!!!
- pcv valve was disconnected!
- I'm Bright..... Not!
- 85 octane in 5.4L
- 5.4 gas mileage
- 7 Quart oil change . . .
- Ford Design vs. Chevy Design
- 5.4 Thermostat
- To those who use Gtechs...Question...
- Good Source Says Ford Is Experiencing Radiator Electrolysis Problems!
- Spark knock update
- TPS mod. question
- Fuel Injection Lines
- 2002 motor specs?
- 5W-20 Motocraft Sythetic
- perf. upgrades= bad mpg?
- Coolant Change
- How Reliable are the 4.6l or the 5.4l engines?
- How long are the coil packs good for on a 5.4L?
- I'm convinced....you gotta do both!
- Getting stock fan off water pump????
- Can Somebody help me?
- I be damned it worked
- 4.6 vs 5.4
- Engine Backfires
- Just bought my new 2002 F-150
- Arbitration advice
- Truck won't start! HELP! (remote starter installed)
- White smoke on startup
- Engine oil
- New 02's have plastic upper intake!!! WTF?
- RPM's drop.
- 4.9 lower intake????????????????
- Whining Alternator
- Preignition & Eng. light
- Engine problem... new sounds!!
- pics of the throttle body cover on a 4.6l
- Engine prolems (Help Please)
- power steering fluid leak
- rough idle with fipk
- ORP but no skid plates...
- Electric Fan How many CFMs??
- 5.4 Plug Change
- Hard To Start
- IAC Help!!
- Help... I need a new motor!
- 5.4 head gasket update
- MAC intake installed!
- intake silecer removal
- 5.4 or 4.6
- Installed Superchip
- 5.4l stalls while in reverse?
- Puff Of Blue Smoke At Startup?
- For those with 02's and the Upgraded Fans...
- engine noise reply
- Check Engine Light wont go off
- Changed plugs have a few questions?
- Difference Between 4.6L and 5.4L
- Piston Slap?
- Chrome & Accessories
- Superchip vs. Diablosport
- 4.6L V8 Performance
- Serpentine adjust?
- engine noise
- WTK: The correct oil filter
- Stock 1999 F150 XLT SuperCab 4.6L V8 Track Times?
- Ooooo!!! A Birthday!!!
- piston slap and engine origin
- Warm engine RPM 2001 - 4.6L Triton
- Oops
- Installing Sparkplugs in '97 F150
- F150 5.4 track times
- V8 to V10 engine swap tech. needed
- Questions on new pistons for L's
- Question for Amsoil Dealers
- Thermostat Temperature
- opinions needed
- confused about battery???
- Test
- 4.6L plug wire recommendation
- A question for the pros...PLEASE help
- Spark Plug Wires, Cap & Rotor
- What's the real scoop with my questions
- Need more power
- What's this connector for
- 2001 4.6 problems
- Where can I find a 01 5.4 or 4.6?
- 5W-20 Oil is pissing me off!!!
- Oil cooler for new 01 Screw
- Hard to service?
- Front end noise?
- tick, tick, tick... on acceleration right after startup...
- check engine light
- What did I di wrong?
- Electric Fans and Control Units
- transmision noise
- 3.8 To 4.2 S/c ???
- First Kill...I mean Killssss
- 4.6 Supercharging
- Edelbrock Shorties Installed!!!!
- Ok, now this is getting annoying.
- Regular Bosch Platinum Plugs
- F150 won't start
- Easy question about piston rings
- Oil Pan
- 97 F150 4.6L pinging all the time
- Rough and blinking check engine light
- Fuel Injected 4.9l
- Ran my truck at the track last night!!!
- Fuel Pump Problem
- Easy swap? 5.4L for a 4.6L?
- 3.000 mile oil changes?
- Trouble code P0430
- Host of issues on a '97 F150 Lariat xtd cab
- ne1 know if i will have trouble with this?
- Cruise control surge?
- Changed Plugs and wires, Now truck runs like %&$#
- Twin turbo....
- Noise coming from engine
- Defrost inop
- First Oil Change
- Informative info on the 5.4 Liter.....
- Lack of power at low RPM when engine been running fr more than 1/2 hour.
- More Burnout Vid's From The "h.p Freak"!!!!!!!!!!!!
- Too Lean, Too Rich - Just not running right !!
- Any petrol engined truck owners in Europe?
- Banks PowerPack
- need advice on mainteance,19,000 miles on 2001 screw
- 98' 4.6 pings only when air temp is low?
- G-TECH Results on 01 X-Cab w/4.6 auto
- 1999 F150 Startup Problems
- The Whotnow F150 Screw Died.
- how long
- any one dyno a 4.6 in a f150
- electric fan?
- 4.6L Engine Replacement--How much $$?
- Recalibrating a Mass Air Flow
- Pulleys and Ram air
- More Air Flow through unused fog light holes?
- FIPK.....is it really better than stock air box?????
- Engine part
- spark plug
- ALT. trouble on an OLDS
- 2000 5.4L runs better cold than hot...?
- Remote Start
- Mass Air Sensor Question--help!
- Reseting ECU
- how many rpm's at 60mph w/ ....
- Do Crown Vics, Mustang GTs and Explorers get Piston Slap?
- engine thunk right after startup...?
- gas or oil treatments
- Ok WHO knows the answer to this one.
- Spark Plugs and Big Hands
- engine noise
- I found somethin really WEIRD!!!
- Throttle Body is dirty
- Removing smog pump
- MSD box and tach
- 351w question ?
- Looking for performance Coils-On-Plugs for 2001 5.4
- Ok boys,heres the truth on my question re: overdrive or no overdrive mileage
- Airaid "Whistle" fix
- can't find a billet grill for 97 XL F150
- Tornadoair-air management system
- survey: 5w-30 or 10w-30
- Mobil 1 $2.94/quart at Target
- Crate Motors
- Fuel Pressure Regulater
- Msg for Mike T.
- 01 5.4l whistle, erratic/high idle
- speedo stuck at 0, what to do?
- 5w-20 syn substitue?
- Anyone dyno their 5.4 auto?
- more blue smoke for 4.6
- Is a New Mass Airflow Sensor Key to Performance!!??
- NO MESS Oil Change
- Any comments on these steps re/rough idle?
- MAF mod underway!1
- Another Check engine light.....
- starter issues
- Whats with the high idle?
- Fuel Filter
- Starting hesitation (4.6l)
- How many miles can I expect from my 4.6?
- Horsepower on 99 5.4 and 01 5.4?
- Need help: New truck needs new engine - what should I do?
- Can Any One Help
- Ruminating About Radiators
- 5.4 won't maintain idle
- Idel adjustment on 5.4 Screw
- Wrong radiator
- Lightning 90mm MAF work?
- Whats a safe oil temp?
- gas in carbon canister
- Rattling Noice when Accelerating
- Trasko Oil filter
- Ok "guru's" What is the mileage diff. between overdrive and drive ?
- 4.6L SOHC to 4.6L DOHC ( NEED HELP !!!)
- Timing question
- 100,000 yesterday
- Engine build up advise
- tick when motor first starts up
- ford f-150 stalling problem
- Mobil 1 question
- Electric water pumps!
- 5w-20 Motorcraft Synthetic Blend replaces regular 5w-20?
- possibly a weird q
- Mobil 1 not enough detergents ???
- 1999 Fuel Injectors 19.24.30 lb
- V10 chip??? anybody install one
- is there a way to test coil packs
- Largest possible swap
- Anyone running JET power pulleys?
- Temp. Sending Unit
- shaking and hesitation on throttle up
- 8.1L Avalanche
- JET Powertech Performance Module
- Helix Power Tower
- ready to order with x-plan
- Troubleshoot this one.....
- 5.4 Triton clicking
- What is up with the Belts?
- Double Oil Filters
- 1997 4.6l triton engine horsepower?
- Need Help! "Service Engine Soon"
- power increases
- CONVENTIONAL VS SYNTHETIC (here we go again!)
