PCV valve
Old May 1, 2005 | 05:40 PM
dirtydawg's Avatar
PCV valve
i have to ask this i have a 5.0 and if you are looking at the front of the enine this is a hole on the left side valve cover that has nothing in the hole does the pcv valve thanks sorry for asking a dumb thing but im new to my truck
Old May 1, 2005 | 08:16 PM
ucfperspicere's Avatar
Sounds quite plausible. I'm sure someone with your type of engine will chime in shortly, but you could also go to a Ford dealership Parts department and ask them. The PCV is something you should buy from the dealer because - for some unknown reason - any AutoZone, Discount/Advance, etc. replacement PCVs seem to rattle.
Also, if you're going to be doing your own simple maintenance you should probably go ahead and invest in a DIY manual, such as Haynes or Chilton's (I prefer Haynes). It'll give you easy-to-find simple answers to lots of these types of questions.
Good luck
Old May 2, 2005 | 10:22 AM
jre86's Avatar
I wish I had seen this thread last week. My PCV valve on my 5.4 L was buzzing. I searched on here and it said to replace the valve even though it was perfectly clean. I went to AutoZone and bought there $3.20 valve. I put it in and it seemed to have the same noise. My idle does seem to be a little smoother. Should I try to get a Motorcraft PCV valve or should I look into replacing the hoses that go to the PCV valve to get rid of this buzzing?
Old May 2, 2005 | 06:34 PM
If it's buzzing it's probably the cheap metal replacement PCV valve. You can get a Motorcraft one from Ford for around $12. For something you only have to replace every 50k-60k (or more), I'd say that's a negligible expense.
Jeff
