Service Engine soon!
Service Engine soon light!
Service Engine soon light came on in my 2002 f150 and is staying on, my manual says it has to do with my fuel? every thing is running ok....any help here
Maybe you didn't put the gas cap on tight. So you can reset the light by doing the following. Check the cap, disconnect the negative battery terminal, turn on the lights and wait a few minutes. Turn the lights off and reconnect the terminal. If the engine light comes on again, you have a problem and will need to get the codes read.
Instead of resetting the computer, go have the codes read at your local auto parts store, WRITE THEM DOWN, and post them back here for discussion BEFORE buying anything.
Just resetting the computer will most likely be wasting your time unless the underlying condition has been resolved.
Steve
Steve
Steve
Steve
