5.4 Is A Dog!!!
Old May 2, 2005 | 12:36 AM
GEO66's Avatar
5.4 Is A Dog!!!
I WAS A CHEV GUY FOR A LONG TIME...LUV THE NEW FORDS GREAT
LOOKS ETC....BUT THE 5.4 WON'T SPIN A TIRE IN THE RAIN WHAT UP? IS THAT NORMAL?
Old May 2, 2005 | 12:44 AM
Johngs's Avatar
I spin my tires all the time...and thats without rain. Im never even trying to spin em either.
Old May 2, 2005 | 01:27 AM
LBC150's Avatar
yea, i can spin my tires with ease
Old May 2, 2005 | 01:30 AM
ucfperspicere's Avatar
GEO, welcome to the boards. First, please remember that this is an online forum and all caps is considered yelling, so if you could let down the caps lock when you post, I'm sure everyone would appreciate it.
As for your lack of wheel spinnage, remember that lots of factors play into that, most notably gear ratio and tire size, which are different depending on your truck's buildout. Also there's loading. If your truck's geared low (3.55 or lower), has tall tires (more than 30"-31" with otherwise stock specs) or is loaded down, it may be difficult to get your rears to spin, especially if you do have the limited slip rear end (which I believe all FX4s do). Also, make sure you're not in 4x4 mode. The whole point of that is to avoid tire slipping.
Anyway, I'd find it hard to imagine that any unloaded truck with a 5.4L engine would not get slippage on a wet road. If everything else is optimal, there may be something wrong, but I'd look for other proof first.
Old May 2, 2005 | 05:58 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Me smells a trolllllllllllllllllllllllllllllllllllllllllll, beware of the troll nome he may find a home. Do not feed the troll nome and he may go home. "I CAN'T SPIN A TIRE IN THE RAIN" he says, I say take a hike i can do it in a metro on a dry day bit@h, so go away troll nome go home.
Old May 2, 2005 | 06:35 PM
PONY_DRIVER's Avatar
That's funny. I rolled my tires today and I drive a 4.6 powered, 3.55 geared, Screw, with a tonneau cover. I think your 5.4 is broken, please send it to me immediately for inspection. I'll return it, postage paid when my inspection is complete.
Old May 2, 2005 | 07:47 PM
lonnie brown's Avatar
got to be in drive before the tires will turn...dugh....with a 355 ltd silp I can lay rubber LT 265 70/17 dry.....try puting the truck in drive num nutty guy...
Old May 2, 2005 | 08:29 PM
Neal's Avatar
HI!... I have NO problems spinning my tires! LOL!
Click here to see Video
Old May 2, 2005 | 08:50 PM
polingt's Avatar
Calling Troyer Performance...
GEO66 give supporting vendor Mike Troyer a call...He'll make that need for speed/performance HAPPEN! Did for me!
Old May 2, 2005 | 09:36 PM
wittom's Avatar
If what your interested in is spinning the tires maybe you should've got a HEMI!
If you had become an informed consumer before you "bought" your F150, you would know that it's a drive by wire. That means that when you jam on the gas you are sending a request to the computer which will evaluate your request and then allow the engine to respond. There isn't a direct link from the pedal to the throttle body. Ford is going to program the powertrain control modual in a way that will be satisfactory to "most" drivers. I would guess that "most" drivers aren't all that interested in spinning the tires. I would also guess that thoes who are interested in spinning the tires are aware of what the aftermarket can do to help achieve that goal.
If you could spin the tires, would you then complain that the 5.4 is a gas hog?
Incidently, my 4.6 F150 is not a dog and can spin the tires. Even when it's not raining.
Old May 3, 2005 | 05:21 PM
01screw's Avatar
Remember, if your tires are spinning, you ain't going anywhere fast!! I prefer my truck to hook up and go rather than sit there spinning my tires.
Old May 3, 2005 | 05:27 PM
jhoparmy's Avatar
Nice video Neal!! I have no prob spinning my tires, in fact, that's my problem, to much tire spin. My 97 5.4 would spin with no prob also. Better contact Mike Troyer about this problem.
Old May 3, 2005 | 06:58 PM
Jordan not Mike's Avatar
True that.
Old May 3, 2005 | 07:36 PM
Quintin's Avatar
And you're hauling around the heaviest configuration F150 you can get, curbing somewhere north of 5000 lbs. I didn't know the ability to break the rear tires loose was a high priority.
Old May 3, 2005 | 08:28 PM
Fx4man2004's Avatar
i got an 04 with a 5.4 and its true on a dry day without any dirt it wont spin but when its when they catn get traction maybe urs is broke serioulsy, anyways these trucks aint for racing
but at that i kinda like not spending the tires cause it lets me get the jump and trust me i need it lol
the 5.4 is a great motor very tame but very nice plenty of power for real
urs is broke!!! has to be
