94 I6 randomly has no spark...
Old Apr 24, 2005 | 08:02 PM
seth ferguson's Avatar
new plugs/wires/cap/rotor/coil/module... all been replaced...
this thing has no spark... once in a while it will crank over and run for a few minutes then it dies and will not restart, i pull the plug out and try to start it and it wont spark against the block... then 1 in 5 times i try it will, and will start right up...
what else is there to replace? this is like completely random... it started doing it once in a while, progressively got worse, and now its been sitting for 8 months...
someone please help!
Old Apr 24, 2005 | 08:16 PM
Bluegrass's Avatar
It's fuel injection so it has a Thick film integrated circuit (TFI) module associated with the distributor.
They often go bad from heat
Old Apr 24, 2005 | 08:45 PM
i looked in the haynes and the TFI they describe looks like the ignition module i replaced... i have the one that mounts to the fender, not on the dist., or is this a different part you are talking about?
Old Apr 25, 2005 | 10:12 AM
BUMP!
