misfire and code
Old Apr 17, 2005 | 11:41 PM
hunting69's Avatar
misfire and code
i have 97 f150 4.6 and ive been having a diffrent spark plug misfire every two weeks i also get code for insuffeceint egr flow ive replaced my spark plug wires and spark plugs dont know what to do. i get a slipping feelin when the misfire occurs also have service light on. mechanic says replce egr valve but im tired of replcing parts with no result, thanks
Old Apr 18, 2005 | 12:33 AM
Bluegrass's Avatar
What are the codes and what have you replaced?
Old Apr 18, 2005 | 01:05 AM
hunting69's Avatar
reply
p0401 egr flow insufficeint and i have replaced my alternator to 120 amp spark plug wires with 8mm bosch exhaust with 3 inch flowmaster and two of the spayplugs that misifred mechanic said other ones looked fine
Old Apr 18, 2005 | 05:22 AM
hunting69's Avatar
seafoam-help me
was alos wondering about using seafoam to clean everything out help me please
Old Apr 18, 2005 | 08:28 AM
projectSHO89's Avatar
P0401 is a very commonly discussed code. Please SEARCH keyword "P0401". EGR Valves are very seldom the problem.
Specify what brand plugs and wires you used.
Punctuation and sentence structure are important to convey technical details. Please consider using them.
Steve
Old Apr 18, 2005 | 10:02 AM
Bluegrass's Avatar
Alternator won't have anything to do with a miss.
If you have no codes referring to a miss, the problem is the EGR operation.
Insufficient flow is a plugged exhaust channel, bad or dirty EGR valve/ sensor.
Take that system apart and clean to be sure the flow is unrestricted, then see what you have.
Don't chase ignition for an EGR indication.
Old Apr 18, 2005 | 12:42 PM
Sgt_Zeke's Avatar
Misfire and code
I am having the same problem and it is always the same cylinder #3. Facing the engine where would that be? Left or Right 1,2,3 or 4 from the front of the enigine. This is on a 1998 F150 4.6 V8. Thanks
Old Apr 18, 2005 | 08:35 PM
bigbronc's Avatar
Sgt Zeke, Your problem is most likely due to coolant leaking down from the heater hose above number three cylinder. To fix the leak, replace the clamp on the hose and tighten it securely. Number one cylinder is on the passenger side at the front. They run sequencially front to back, 1-4. Number 5 is at the front of the driver's side. Hope this helps.
Robbie
Old Apr 18, 2005 | 11:29 PM
hunting69's Avatar
tire this
i carried it today to have the entire system as in the fuel system cleaned and flushed and light went away for now ....
Old Apr 19, 2005 | 11:09 AM
Sgt_Zeke's Avatar
Thanks Robbie that is everything I hoped for and more than I would get from the dealer or the local repair shop. It would also explain why it would reoccur after a period of time. I will check out tonight.
Mark
