Windsor vs. Romeo
Old Apr 22, 2005 | 05:09 PM
Barsnstars's Avatar
Windsor vs. Romeo
I was just wondering is there any difference at all between the Romeo and the Windsor 4.6 liter. I noticed that my friends with f-150s all have romeos and mine is a windsor. Seems kinda odd considering most of them came from the same dealership in the same year.
Old Apr 22, 2005 | 05:31 PM
Neal's Avatar
HI!... IMHO the WINDSOR built engines are better than the ROMEO's. Everytime I've heard of problems with a 4.6, I would say 75% were the ROMEO built one. The timing chain tensioner/guides are a bit different between the two, the ROMEO heads have a girdle on the cam mains. The bottom ends are slightly different as well. The ROMEO 4.6's are mostly passenger car engines. All WINDSOR 4.6/5.4's are truck engines. Be glad you got the WINDSOR.
Old Apr 22, 2005 | 05:46 PM
Barsnstars's Avatar
Thanks for the help Neal and yeah im very happy with the Windsor man that truck is quick, never knew why it smoked the romeos till now. Still have a problem with one of the pulleys though. Other than that its great.
Old Apr 22, 2005 | 07:16 PM
Faster150's Avatar
the windsor 5.4L engines were the one which had the plug spit out of the heads and the VCT problems in the new 5.4L 3V with the valves ticking... should i pull out the recals and such... and compare romeo's to windsors. all the SVT engines are romeo's not windsors.... and my truck has a romeo. alot of trucks have the romeo's.
Old Apr 22, 2005 | 10:47 PM
Neal's Avatar
HI!... FASTERF150 : Both the the ROMEO and WINDSOR used the same 4 threaded sparkplug holes in their heads from "98" to " 02". 99% of all 5.4's are built here in WINDSOR not ROMEO. That includes the 5.4 3 valve as well. All SVT "passenger car" 4.6's are BUILT in ROMEO. ALL SVT LIGHTNING 5.4's are built here in WINDSOR. Actually over 80% of F-150's get the WINDSOR built 4.6, not the ROMEO.
Old Apr 22, 2005 | 11:05 PM
Neal's Avatar
HI!... This site here will tell you the differences between the WINDSOR and ROMEO 4.6's. After you read it you will see why the WINDSOR 4.6 is a better choice. (for a truck at least).
http://www.babcox.com/editorial/ar/eb40228.htm
Old Apr 26, 2005 | 05:26 PM
minimustangs's Avatar
Differnce?
So how do you tell the difference between a Romeo & Windsor engine??
Steve
'98 F150 XLT 4x4
'97 Mystique LS
'94 Mustang 5.0 Conv.
Old Apr 26, 2005 | 10:04 PM
Barsnstars's Avatar
Well all I can tell ya is mine has a sticker on the driver's side of the engine that says 4.6 liter Windsor and they are supposed to have a W stamped on them somewhere
Old Apr 26, 2005 | 10:55 PM
Johngs's Avatar
One way to check is the VIN...
http://www.fordf150.net/howto/decodevin.php
But if the sticker is still on the engine, you can look there too.
Old Apr 28, 2005 | 11:58 PM
Faster150's Avatar
http://www.modularpower.com/engine.htm
see even ford says that the romeo plant makes better engines... and every single high performance engine that ford makes comes out of the romeo plant not the windsor plant....might also be because its in romeo,michigan not windsor canada :-p
Old Apr 29, 2005 | 10:08 AM
JMC's Avatar
JMC
25 Year Member
I believe that that article was meant to promote Ford's skunk works and the new line of vehicles Ford will be coming out with. It would be politcally incorrect for Ford to showcase a "foreign" plant.
Regardless, if you look at the basic differences between the Romeo and Windsor 4.6 you will see that the Windsor is inherantly a stronger engine. For example the Con rods are bigger or the dowels holding the mains in place.
Regards
Jean Marc Chartier
Old Apr 29, 2005 | 09:29 PM
PONY_DRIVER's Avatar
Well here's a dumb question. Why would Ford build 2 different version of the same engine, and even have different blocks? i.e. Knock sensor beoing added to the Romeo's when the Windsors had them from day one? I can see using different connecting rods, pistons, and rings for different applications but damn!
Old Apr 29, 2005 | 11:17 PM
Schism9's Avatar
Cause it's Ford.
Old Apr 30, 2005 | 01:06 AM
Faster150's Avatar
windsors have always been mostly truck engines and the romeo's have always been for the performance and cars mostly so they never had nock sensors cause the head designs were better on the romeo's till lately when they started using the same head design as windsors they started to nock and so they added the nock sensors.
Old Apr 30, 2005 | 04:54 AM
Neal's Avatar
