royal purple oil
I have heard that it is a decent oil, but it shears quickly. I wouldnt run it for 10,000 miles based on what I have heard on www.bobistheoilguy.com
For the money there seems to be better choices out there.
I have ran it in my 99 5.4 for a couple years now. Its got 120K without any troubles. I change mine every 5 to 7k, sometimes those miles go by before I get a chance. When I started using it, my engine idled smoother and since running it in every thing from the engine, trans, rear, and water pump I regularly get 18-19 mpg and I run this truck hard.
But oil seems to be a touchy subject on here.
Sled....
Sled....
Royal Purple is indeed a very high quality synthetic oil. However I saw that your truck is a 2002 model and are using a 5W20 weight on it. If your truck has over, say, 65K miles i suggest moving up to a 5W30. This will provide your engine with greater protection when the engine runs warm. Also, oil's life decreases with increased engine temperatures(Generally city traffic) The best recommended interval for this kind of oil would be in the 6K mile range. Slightly higher for highway use.
im running the 5w20 because i heard that if you go with something different and something goes wrong it would void your warrenty. and i only have 36,000 and have the extended warrenty until 48,000. so im following the book until its up to be on the safe side. 98% of my travel is highway. so i guess i will change it around 8 grand.
If using anything other than 5W20 will void your warranty then my dealer will eat it for sure. Back in the days when I didn't do my own oil changes (no longer since a bad experience at a dealership) the dealer always pumped 10W30 even when I demanded 5W30. Once I even had it put on the service ticket before it goes in and they still put in 10W30. (According to the little reminder sticker they put on your windshield) All the service person could say was "Oh don't worry it won't hurt anything". That wasn't the point idiot.
Originally posted by Johngs
He never actually said he runs 10k intervals.
Neither says what he currently changes at...
If you were to have any problems on claiming a warranty based on oil, it most likely would be because of how often you changed it(even using synthetic) not weight like LeanNCut was saying. However I really doubt you would have problems either way, if some dumbass dealer said no because of it, take it to another.
I DONT KNOW WHAT AND WHAT WONT VOID IT. IM JUST STATING WHAT I WAS TOLD AT THE DEALERSHIP. I CHANGED BEFORE 3000 WHEN I WAS RUNNING MOBIL. THAT IS WHY I ASKED BECAUSE SYNTHETIC IS NEW TO ME AND I WAS HOPING TO GET FEEDBACK FROM OTHERS WHO HAD USED IT THATS ALL. ARE NOT THESE FORUMS TO ASK AND LEARN THINGS THAT IS WHY I STATED MY POST IN A QUESTION FORM. NEXT TIME I WILL USE A ? MARKS WHEN NEEDED MY BAD.
Frankly, I don't know why you would use Royal Purple when Mobil 1 is available. Mobil's R&D and experience in virtually every form of driving/racing imaginable just can't be beat; and I think the product proves it. Full Disclosure: I used to work for Mobil in their lubes division -- if you were able to see the teardowns, proprietary information, tests, etc., as I have, you'd think the same way.
Everyone has their own perferences, though, and I'm not trying to go overboard, so apologies if I've offended you -- I didn't intend to. Btw, if you decided to use Mobil 1, depending upon the conditions you drive in, you should have no problem going 15K between changes.
