Help on Adjusting Throttle Cord
I installed a BBK throttle body on my 5.4L a few years ago and had the same issue. I had a part laying around that worked to shim out the play on the throttle pedal end. Basically, it was like a cable clamp that I could put in between the end of the cable and the top of the throttle pedal level under the dash. Took out the slack nicely.
Not sure what you could buy from a hardware store to do the same trick - maybe others have some ideas...
Good luck!
Bernie
Good luck!
Bernie
Location: Houston, by way of every major city in America.
on
I took up the slack behind the pedal on mine, with a couple of cable ties wrapped around the cable. Everything worked fine until one night at three am. I was about three blocks from home and bumped the pedal at a light. The pedal went slack under my foot, and I had to idle home at 3mph. The cable snapped. I learned to leave it alone after that. The good news was that a new TB cable was about $24, and took as many minutes(or less) to install.,,,,98
