- Best air filter ?
- Odd starting behavior when warm
- 4.6 air/fuel fluctuates wildly
- Anyone Have a TimeSert 5553 Kit for sale?
- Engine idles bad when AC is turned on when in drive
- Can you tell me?
- Need Advice: (Tired Topic But Bear With Me)
- OEM Ignition Coil Packs vs. Aftermarket
- distbor installion
- Could use some help on a 5.4L 3V project
- Engine running rich...
- Hard Start
- For the Toyota Lovers. ;)
- V10 Swap
- E85 Fuel in an F150
- Engine repair...is this for real?
- NO What is the Best OIL Thread
- Were is the power
- DPFE sensor ?
- 1998 f150 engine swap
- AEM BruteForce Cold Air Intake and Throttle Body spacer
- Replacing the fuel filter
- Head ?'s
- CAT's Split
- more power
- where can I get a firewall plug?
- Amsoil Dual Remote
- 95 302 wont start unless primed
- This is a little scary...
- How big of a problem is HOT air intake?
- Check Engine Soon/P0306
- POP goes the coil cap
- Anyone have a Timesert Kit 5553 to Rent
- maybe a stupid question on engine horsepower
- Probable cause for 5.4 misfire?
- 2001 5.4L intermittent stumble
- DPFE Fix
- 4.2 intake gasket change Houston, tx
- HP and Torque Ratings of 02 PI Engine
- whats next?
- Spark Plugs
- Cold Start-Up Noise
- Gas into Diesel
- engine sometimes dies at stop sign
- AC problems
- power loss???
- Overheating
- bigger engine
- Fuel Injector Harness Type
- P2196 - O2 stuck on rich
- Vin code says engine rated a 250hp ?????
- Cam phaser costs?
- tune-up and preventive maintenance
- Better Gas Mileage? Ideas?
- 2000 Ford Expedition Engine Problem - HELP PLS!!
- Max mileage?
- Spark Plug Replacement at 190k?
- truck boggs, then cuts off, please help
- Serious Question...
- Ford 3\4 ton
- Engine quit on a hill
- Fast startup, valve traine noise '05 5.4L
- Another LEMON!!!
- pics of FAL efan brackets/installation?
- SEAFOAM ?'s
- Rislone
- Squeel from Serp Belt
- 4.6 L vs 5.4 L
- engine problem
- noise
- Efan indicator light suggestions?
- Error code p0443..Think dealer is on crack
- OBD II Scanners ?
- Evap Help Plz
- heads cams...bolt ons 1997 F150
- 2000 F150 questions
- Stuck #4 Plug
- What is this...?
- 97 4.6L to 05+ 5.4L swap??
- Service engine light
- 2009 F-150
- What restricited air flow on the 460 mammoths
- 02 sensors?
- 02 sensors?
- Edelbrock Carb worth it?
- blew plug... bent valve
- A/C compressor pulley rattle.
- Engine code ????
- Help with Vortech Pulleys
- F15****ty!
- Engine Swap
- pinging issues still
- Aftermarket Heads, Cams; Stay NA?
- 3.08 to 4.10
- wind resistance from roofracks, running boards and cladding?
- Need Help Tuning Diablo Sport Predator Performance Programmer.
- 2006 5.4
- fuel mileage.
- O2 sensors?
- knocking and pinging
- Engine mods & warranty
- Troyer fan failed
- royal purple oil
- 5.4L Buzzing/Raspy sound?
- 1999 5.4L Running rough under a load. HELP!!!!
- f150 sputtering or stuttering
- Octane Boosters...
- Anyone need some plug wires?!!!!
- hard starts
- Bank 1 running too lean
- need help please...
- New spark plugs
- engine swap
- valve train noise?
- Changed altenrtor/ now air bag light is on/need help
- not starting
- Engine Misfire
- To many parts??
- Romeo vs Windsor 4.6L engine swap question
- engine restore
- Was cyl #8 misfire, now TPS circuit low input
- 2005 5.4 keeps stalling
- Finally got brave and did it!! I'm proud.
- power steering problems
- Valve Rattling
- Metal Flakes on top of Motor
- p 1056 code. Question
- Thottle actuator problem
- Nice little story.
- COP Kits R Back -
- Oil pressure guage is pegged
- Nitrous
- How to replace vacuum line from EGR valve
- Relocating coolers
- Royal purple..How long between changes?
- Engine sticks at low RPM
- Ultimate modular V8
- WTF is wrong with my Truck
- PO 175 Bank 2
- P0157 code
- 5.4L Triton Crate Replacement?
- Electrical Charging Problem
- Condensation coming out of tailpipes
- Got Police Interceptor Engine for 2000 F150
- Engine or Transmission
- Thud when starting
- Check engine light on, EGR insufficient flow
- Service Engine Soon Light ON
- oil filters
- Who has the highest mileage on an 04+
- Can Someone Please Help...
- Dead!
- Flex a Lite 270
- Whos got a 4.6 with an edge evo?????
- Wiring up Electric Fans
- Blown or Broken Plugs
- Orange Coolant? Where to buy?
- overheat engine w/a/c
- Truck Is Down
- '92 F150 engine reving when clutch is engaged
- How to get the most from your facotry 460?
- Engine Squealing
- Starting Problems
- Hesitation
- Engine Coil Failure...3 Times?
- Wierd Sound On Acceleration!
- 05 5.4L No power on passing
- Newbie with a couple questions
- Convert 01 F-150 to run E-85 flex fuel
- engine skip
- Problem with Engine or Transmission?
- ITS ALIVE!! new 4.6 but more ?'s
- Replacing Both Head Gaskets
- oil capacity
- real quick seafoam question
- 2005 f150 engine swap
- Throttle Body Cleaning
- Supercharger for 06' 4.6L F150....???
- 351 engine
- I have a 2006 4.6L F150, and i was wondering..
- Engine missing and has a P0113 code
- Broken Bolt
- suddenly stalls
- Power Steering Hose 5.4 -- replace question?
- Do engine programmers void Ford's warranty?
- 5.4 spark plugs
- 5.4 Tapping
- How to improbe fuel economy
- Diesel for F150
- lighting intake/whipple on 5.4 2 valve
- F150 bad igniton noise
- diagnostic trouble code b2825
- header
- Opinions on oil
- What should I R & R?
- leaking coolant at throttle body
- weird popping sounds
- I'm at wits end!!!
- Finally "Got-R-Done"
- oil differences
- Hypertech programmer 3 with Nitrous oxide?
- oil consumption
- Ford Smoked Everybody -2008
- 5.4 engine noise at startup
- What coolant?
- broken bolts.
- I've searched - COP change on 1998 5.4
- How much HP?
- K and N filter worth it.
- Okay Now
- 1990 Fuel pump problems
- Lifter rattle at start up.
- possible exhaust leak...
- Cam Position Sensor - Multiple Failures - 4.6L
- 3 cylinders misfiring codes
- Wheel Hop
- 1997 engine swap 4.2 to 4.6
- "Whistling" noise in cabin...
- spark plugs
- Super charger
- 07 Only 500 miles, P0345
- What engine in my 65 pontiac parisseane.
- 2005 5.4 comp cams
- Just got done chaning my oil-Mobil 1
- Driveline Loss?
- Front tank in '92 leaks when parked uphill
- E-85
- oil????
- EGR problems on a '92 5.0
- help cel code p0401 egr valve
- I really need help
- Cam question
- Idling
- vacuum lines
- Battery Idiot Light 01 F150
- Coil Pack quality question.
- high idle on start up
- Hesitation and then a jerk
- Start up rattle
- I have replaced 3 or 4 COPs - Do I have an underlying issue?
- power programers and chips...
- Help for a noob
- 4.6L blew up today
- Horsepower on a budget ...
- oil
- 96 f150 won't start
- 1992 EGR question
- 2002 F150 5.4L Engine misfire HELP>??
- BMW motor
- Ever Call Ford in Deerborn?
