Help/info appreciated
going to buy a 2001 lightning longblock without the supercharger. nothing is wrong with the engine or rotating assembly, plans are to keep it n/a for a few years then eventually turbo it down the road. my question is what can i do to raise the compression without changing the pistons......milled heads my only option? or should i just go ahead and swap out pistons/connecting rods and leave the heads alone for now? I plan on installing new cams and of course im going to need a intake manifold, is there any aftermarket ones that i should look for? this is going into my 2001 4.6 4x4, whenever it decides to die, so i'll be able to work on the 5.4 whenever, and install everything with it out of the engine bay. any help is greatly appreciated and thank you!
yeah, f/i it would be ideal. but for now its just going to be n/a, so i think its only right if i just swap out pistons.
The rods will be the weak point later down the road when ya go F/I.
Phil
As long as you using the same trany, (yes) the 4.6 pcm can be tuned to run your new setup.
I thought you said you were just going to run it with the stock internals?
If that's a L motor , it has forged pistons and crank. So the weakest part is the rods.
I'm not positive but I think the H beam rods are strongest. But ether will work just fine.
Your not going for over 1000 RWHP are ya? lol
Phil
Phil
ok, then thats the plan, build the 4r70 when the 4.6 dies and swap in the 5.4. I've been thinking since i have the block on a stand i should just go ahead and swap in stronger rods since i've heard they aren't that strong. and 1000rwhp would be nice, but not in a daily application for me hahaha.
also, is it worth porting/polishing the heads? if i can get by with cams and not needing to p/p the heads then i'm not too worried about it.
You can get away without porting the heads, but you will make a lot more power if ya have them done.
If you do have them done, have them redo the spark plug threads with more threads so you never have to worry about blowing a plug out.
When I had my heads worked, they welded in the plug holes and re drilled them.
Phil
Phil
