need advice for spark plug removal
Old Sep 21, 2010 | 02:43 PM
jemckinney's Avatar
I am changing out my spark plugs and I am going to put in ngk ht0 plugs because I have a supercharger.
A few questions that I have, what size socket and extensions should I get before taking out the plugs?
I bought some PB blaster a spark plug gapper and some anti seize to put on the new plugs. I was going to get the coil packs out and the plugs exposed and let them soak in PB blaster tonight.
I am concerned with the plugs breaking so any advice there to limit breakage.
One other question, the guy at advanced auto said not to gap the plugs I am going to put in because it could screw up the platinum wire in them, so what should I do about this?
Thanks!
Old Sep 21, 2010 | 03:10 PM
jethat's Avatar
follow the TSB
http://ww2.justanswer.com/uploads/jm...sb08-07-06.pdf
Old Sep 22, 2010 | 04:09 PM
Since when does NGK make 3V plugs?
If you have a blower, get the Brisk 1 piece plugs and change them every 20k.
Old Sep 22, 2010 | 04:58 PM
jemckinney's Avatar
sorry they are autolite not NGK
