White Smoke on Initial Start Up??
it only does it after it has sit for a couple days. not smelling any antifreeze.
i think its more than normal condensation burn off.
There are no other sources for white smoke besides condensation or coolant... (unless someone plumbed yer WW fluid into yer intake, lol)
Confirm you DO have a 50/50 mix in yer system and not just plain water ... (or a very diluted mixture) - used truck, remember ....
EDIT - or, is a buddy playing a joke on you and adding a little Seafoam every day (dat dirty rotton, lowdown cotton socktucker)
Paging Jbrew
MG 'effinD
ill check the PCV valve, might not hurt to replace it.
on
if its coolant i should be able to tell by looking at the oil though right?? Not all leaks show up in the oil. if it is only leaking into the combustion chamber it will never show up in the oil.
ill check the PCV valve, might not hurt to replace it. Replacing parts that are not defective is a waste.
ive put a couple hundred miles on the truck now and i know the overflow for the radiator hasnt went down. while its cool i need to go check the radiator itself. planning to flush that within the next couple of days while the weather is nice.
so im not noticing coolant level dropping nor am i seeing oil level dropping. hopefully its nothing to worry about, but it bugs me. seems like a little more smoke than it should be. ill let it sit a few days and start it up and watch it closer and try to smell it.
thanks for the help thus far.
[QUOTE=ryanh_johnson;4361273]its not cold here....im in arkansas, been in the 40s for lows.QUOTE]
Thats cold enough to get some good condensation when you start it. Both of my Fords and the wifes Nissan has the white smoke in the mornings on the first startup and its in the lower 50's here.I dont think you have any worries.
[QUOTE=KingRanchCoy;4361833]
well im glad to hear all the positive remarks!
thanks everyone for your input.
