5.4L Engine Noise
5.4L Engine Noise
Hi all.. Need some advice and direction.. got a "02 F150 5.4L w/ 75k on the odometer.. When cold, there is a very slight single knocking sound until the engine warms up.. then as it warms up, the noise goes away..
Oil pressure is where it always is and I'm running Royal Purple 5W-20 oil. Idles like new and has plenty of power.. no oil burning..
Not sure if I have a problem arising or not, but need some input from those in the know..
Piper62j
Piper62j
5.4L Engine Noise
Hi all..
Need input and advice.. Got a '02 F150 5.4L w/ 70k on the clock.. Never abused... Idles smooth and has plenty of power all the time.. does not burn oil or smoke in any way.. Auto trans 2WD standard cab, short bed..
When cold, I can hear a slight knock until the engine warms up. then no noise at all.. Oil pressure is where it has always been which seems normal...
Any suggestions??
Piper62j
Any suggestions??
Piper62j
5.4L Engine Noise
Hi
Need help, guidance & suggestion.. '02 F150 70k on the clock.. Standard cab, short bed automatic.. 5w-20 Royal Purple, doesn't smoke or burn a drop.. Runs very smooth and plenty of power..
Very slight knocking noise when cold.. dissappears when warm...
Any ideas out there? Am I looking at a potential problem or is it not engine related?
Piper62j
Piper62j
arnt the 5.4 knowen to piston slap? put some 10-30 or 10-20 what ever its say's..( change the 5 to 10in it) it will go away.. its no big deal.. Do you tow alot?
User has two threads going fellas, same question. Here's the other -
https://www.f150online.com/forums/ex...ine-noise.html
piper62j - Please don't start multiple threads on this site with the same or like question.
Thanks.
BTW- Incorrect oil filter, - yours = FL820
Thanks.
User has identical thread going, here -
https://www.f150online.com/forums/v8...ml#post4385748
Thanks.
Thanks.
