I need Advice!!!
Old Oct 25, 2010 | 10:05 PM
Sigma4's Avatar
I need Advice!!!
I have a 2003 F-150 5.4 Triton FX4. As of about a month ago it began jerking when i would go up hills and during light acceleration. The local auto parts store suggested that i replace the EGR valve and DPFE Sensor, but the problem has worsened. No check engine light so no codes. Also i am showing a warning notifying me that my gas cap is loose, but it's not. Anything?
Old Oct 26, 2010 | 12:25 AM
luvmyfordalways's Avatar
You can have codes without check engine light coming on. Check plugs for sure, one may lose and fixing to blow out, and also unplug one coil at a time and see if it effects the idle. If the idle doesn't change when unplugging one, good chance the cop is bad. Just went threw this on mine. Have a parts house ready your puter and look for yourself to see what they may be and write them down and then come back and post.
Old Oct 26, 2010 | 02:08 AM
Exactly what is telling you that the gas cap is loose?
You may be due for new spark plugs and/or coils.
Old Oct 26, 2010 | 07:36 AM
Sigma4's Avatar
I will definitely check the coils and plugs.
There is a warning light to the far right of the guages that shows an unscrewed gas cap. I've replaced the cap twice and the light keeps coming back.
