5.4 Crankshaft Woodruff Key
Anyone know of a source to find a "hardened" woodruff key for the crank on a 5.4. I'm not sure if the stock key is hardened or not so I'd like to find someone that offers one so I can be sure it is hardened. Using the 2 piece trick flow crank gears and the larger crank pulley I want to make sure it's a hardened key to support the stress.
Thought about that but hate to do that. May just weld the TF gears together and hope it holds. I'm using a larger crank pulley so there should be a little less torque on it than if it was a small pulley.
