#5 spark plug full of anti freeze
Covered meaning coolant in the sparkplug well (external) or coolant on the plug when it's removed from the plug hole (internal)? I think you mean external but just want to make sure. Number 5 is the first plug at the front of engine on driverside. The thermostat goose neck and coolant outlet hose are almost above it. It is possible thats where the coolant is leaking and dripping down into the plug hole. The other possibility is in the same area but look at the intake gasket area. The gasket in that area can be a problem.
