P0171
Old Sep 26, 2010 | 10:33 AM
wutagoalie's Avatar
P0171
Just scanned and P0171 came up. Lean Bank 1.
just the 1 error code, I have tried a search, but suggestions were all over the place.
What is the usual culprit for a P0171?
New Motocraft plugs, wires and PVC valve 3 months ago.
99 4.6L 2WD
thanks.
Old Sep 26, 2010 | 10:38 AM
jbrew's Avatar
Old Sep 26, 2010 | 11:58 AM
jgger's Avatar
Check for vac leaks.
Old Sep 26, 2010 | 12:33 PM
wutagoalie's Avatar
The hose that runs from the PVC valve to the back of the manifold?
Old Sep 26, 2010 | 01:41 PM
Yep. Also, if you didn't use a Motorcraft PCV valve, get one.
Old Sep 26, 2010 | 01:52 PM
jbrew's Avatar
Yep, clean the MAF and make sure you haven't any air intake leaks. - Like at the IAT grommet. You can also check you intake gaskets with propane.
Old Sep 26, 2010 | 02:20 PM
jgger's Avatar
At that age a little fuel injector cleaner wouldn't hurt either and a new fuel filter.
Just a few maintainence items to add to the above.
