2003 5.4 Rev Limiter?
Old Oct 31, 2010 | 12:59 PM
LittleTow's Avatar
Hey guys, does the 03 5.4 motor have a rev limiter in stick trim? If so has anyone ever bounced up against the max RPM on it? Curious
Old Oct 31, 2010 | 01:01 PM
shifty_85's Avatar
im sure im wrong but i wanna say its right around 5,300
you can get a tuner and people have spun stock motors to 6,000 but its not recommend every day.
i got a tuner and mine 1/2 shifts at 5,500RPM no probs yet....
Old Oct 31, 2010 | 06:25 PM
JMC's Avatar
JMC
25 Year Member
I am going to say 5500 rpm in drive and 4500 in neutral. Just so you know, the tachometers are not very precise and can be off a few hundred rpm.
Old Oct 31, 2010 | 11:13 PM
Don't try to bypass it without getting a built torque converter - the stock converter can balloon on you if you overrev it. The engine can handle a lot more revs than the TC. I think it's 5400 for the TC but the engine is good to about 6500.
Old Nov 1, 2010 | 11:28 AM
LittleTow's Avatar
All good info guys, Thanks but does the truck actually have a limiter in stock trim?
Old Nov 1, 2010 | 12:12 PM
Yes. The tranny will shift before it hits it though.
Old Nov 1, 2010 | 12:15 PM
LittleTow's Avatar
Unless you have it in first gear:-)
Old Nov 2, 2010 | 04:36 PM
Veteran: Army
or locked in second doing a burn out
or locked in thrid maxing out your 140 MPH speedo and still gaining speed
Old Nov 2, 2010 | 06:24 PM
phil6608's Avatar
I don't think his speedo goes to 140MPH
Phil
Old Nov 3, 2010 | 01:04 PM
LittleTow's Avatar
Phil
No I think you guys have me beat there but I do have an old T-Bird SC that gets it pretty good:-)
Old Nov 3, 2010 | 01:38 PM
phil6608's Avatar
I have the same 100MPH speedometer that you do.
One of these days I'll get around to swapping in the Lightning speedo I have for it.
Phil
Old Nov 3, 2010 | 02:24 PM
JMC's Avatar
JMC
25 Year Member
Phil
My speedo indicatesd up to 160 Km/hr ( 100 mph in small font ) and I reprogrammed the tire size and gear ratio so that while it still indicates metric it is actually mph. I now have a 160 mph speedo.
Old Nov 3, 2010 | 02:31 PM
Veteran: Army
Cool
when you pasted that up in your thread, it made me want to get a metric lightning speedo and set it up the same way
Old Nov 3, 2010 | 08:06 PM
avfrog's Avatar
Damn you and your blower...
Old Nov 3, 2010 | 09:32 PM
jethat's Avatar
my mach i has a 120 mph speedo. It would do it but I've never gotten close. I converted the tranny to a TKO600 this year replaced the rear end converted to rear disc got a new trac loc and regeared to 3.73 this year. I took it out and opened it up to 100 for a few seconds. I'm sure the car would do 140 now.
