Throttle Position Sensor Bad?
It is a 5 volt signal, so 18% of 5v=.9v which is within range, as is 93% or 4.65v. If the value was zero would the engine start at all?? Dunno.
The pcm checks the voltage from the tps on start up and uses the returned value to operate.
