Elusive Vacuum Leak
Old Nov 12, 2010 | 11:10 PM
FX4LIFT's Avatar
Elusive Vacuum Leak
Hey guys,
I am experiencing the P0171, 172 codes along with P2195 and 97. can hear pretty substantial vacuum leak, cannot pinpoint. RPM increases when I spray the back side of bank 1. still cant pinpoint difinitively. is there a vacuum port back there, or is my fear of a bad intake gasket coming true ?
Old Nov 12, 2010 | 11:18 PM
How's the PCV elbow at the back of the intake under the throttle body?
Old Nov 12, 2010 | 11:24 PM
FX4LIFT's Avatar
glc,
I think my elbow is on the side of my TB. (Bank 1) could be wrong. will check behind the TB tomorrow. Thanks.
________
04 5.4
Old Nov 12, 2010 | 11:35 PM
FX4LIFT's Avatar
glc,
I experienced one of those no start hissing backfires you read about here alot. Does that lead you to think of any other possible leaks? I am spraying areas with carb cleaner but wondering if the overspray is effecting other areas. wont idle on its own long enough to do a lot of searching. Thanks for any ideas.
Old Nov 13, 2010 | 10:21 PM
JMC's Avatar
JMC
25 Year Member
Check all the connections/hoses between the MAF and the Throttle Body.
