Bad Fuel Pump??
Bad Fuel Pump??
Hello!
I have an '05 F150 5.4L (99k miles) that I think is in need of a fuel pump but I want to be certain before I purchase one. I had the dealer do a diagnosis and they said "bad Fuel Pump". Will a fuel pump Gradually go bad or just die all at once??
Is there anything else I can check first??
Symptoms:
-Loss of power
-Rough running and Back firing through the intake during FAST accelloration
-Sluggish and uneven accelloration. Doesn't act like a "Misfire" but more like it's simply not getting a steady stream of fuel
What I've already done:
-Replaced fuel filter (5k miles ago). This Helped a ton right away but the problems came back pretty quick.
-Dealer replaced a fuel injector (Sudo Recall). No great difference noticed afterwards.
Any help would be appreciated!!
PS: If it is a fuel pump, which is the best approach?... to drop the gas tank or remove the truck bed?
Symptoms:
-Loss of power
what you describe sounds like the fuel system is backing up. so yes most likely the pump. when you buy a new pump don't go to the dealer they cost too much. just make sure it's made buy Bosch. bosch manufacturers them then sells them to different companies, like ford, or napa, whatever. dropping the take is gonna be way easier then taking the bed off, but if you can drain the tank do so it will be much easier.
Do a fuel pressure test before you buy/take anything off.
I think, someone will chime in here, the 05's had injector issues. At 99k you are still covered, search here and you should find alot of stuff about the injector issue. I think it is Stealth that has a link to the recall letter in his sig.
Hello!
Symptoms:
-Loss of power
Symptoms:
-Loss of power
Not well, if at all. Did you take a look at your FPCM? If it looks like it has lost the battle with the salt and snow/water in your area of the country, it's a good possibility, if it doesn't look like that, you're gonna have to check pressure and flow.
