.30 oversized block ?
Old Sep 28, 2010 | 01:37 AM
dannyh73's Avatar
i want to go .30 over on my 01 f150 block and want to know what kind of mods i would have to do to the top end? or will i be ok with rebuilt stock pi heads? can any one help me out?
Old Sep 28, 2010 | 06:04 AM
Veteran: Army
why does your block need bored 30 over???
Old Sep 28, 2010 | 09:34 AM
Galaxy's Avatar
And I think you meant .030, no??
Old Sep 28, 2010 | 12:05 PM
ncTidalWave's Avatar
If you actually meant 0.3" and not 0.03" then:
I don't know what engine you have, but...
if you have a 4.6L, you'll get a 5.4L,
if you have a 5.4L, you'll get a 6.36L.
In any case, you'll probably get a big ball of fire as a best case scenario (if you don't completely cut through the cylinder walls that is), these engines are not meant to be bored out like that.
If, on the other hand, you simply had typo, and meant 0.03" you would get a much more reasonable 4.67L and 5.5L respectively.
I have no idea what you would need to do if you're only boring out 0.03", I just wanted to point out that, if you had in mind to bore 0.3"...it's probably a bad idea
Old Sep 28, 2010 | 12:29 PM
dirt bike dave's Avatar
If your motor is fine and you are strictly looking for a performance increase by putting in .030" bigger pistons, you will get an un-noticeable power gain at a huge price.
Well, I guess if you raise the compression ratio you would get a noticeable power gain, but you could do that just as easily with a stock bore.
If the cylinders are damaged so bad they need an overbore and the motor needs rebuilding, it will probably be more cost effective to drop in a junkyard motor with a little life left in it.
Old Sep 28, 2010 | 01:40 PM
dannyh73's Avatar
sorry minor typo i meant 0.03. and i was just pondering the thought of the work and the benifits.
Old Sep 28, 2010 | 02:18 PM
Veteran: Army
zero benefits...
Old Sep 28, 2010 | 02:51 PM
Boring 30 over is not done for any performance reasons - it's done when rebuilding an engine that has worn or scored cylinder walls.
Old Sep 28, 2010 | 10:40 PM
avfrog's Avatar
Even a .060" over bore doesn't make much of a difference.
Old Sep 29, 2010 | 11:21 AM
jbrew's Avatar
Maybe he's trying to bring back the 360 ?
