preventive maint.
i purchased a 2005 f-150 5.4 3v truck used.it has 140,000 miles.it has a distinct ticking on pass. side,runs fine otherwise.i would like to change the phasers-chains-tensioners. i am retired and have plenty of time,have built several drag engines but have no experance on ford 5.4 triton.i have all the standard tools and factory manuals.what special tools (if any) would i have to purchase?
thank-you johnkraus7@sbcglobal.net
Have a look at this how-to. It should get you started. There are a lot more of the how-tos here.
https://www.f150online.com/forums/ar...placement.html
The wedges keep the timing chain from falling off the crank sprocket, so that you don't have to remove the front cover. If you're planning to replace the chains, then it's not needed. I don't know about the cam lock - that may be needed to time the cams regardless.
