PDA
View Full Version : 2004 - 2008 F-150
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219
  1. 08 f150 Vct wont work when hot after long drive coming to stop
  2. Interior lights won’t come on
  3. Pleased with MPGs this weekend.
  4. 2008 F150 FX4 Refresh
  5. Rear End Swap
  6. Moving to 2021 forum
  7. Spark Plugs Different
  8. 06 F150 shifting problems
  9. ATS flares still available?
  10. Odd issue with my 2004, probably caused by me...
  11. Rear slide window swap to solid glass
  12. Please Help... 2004 F150 push button start no power
  13. Transmission swap problems...
  14. 2005 f150 5.4 misfire timing codes fixed
  15. Do RPMs increase when tranny slips?
  16. 4x4 fuse 111 blows
  17. Lower dash part near carpet
  18. Grooved idler pully wobble
  19. Squealing under load while accelerating
  20. 2008 F150 drive shaft replacement
  21. Quick question....??
  22. No crank no start after trying to program key fob
  23. V6 and V8 exhaust compatibility.
  24. Cant Shift Outta Park 06 F150
  25. Engine knocking almost quit after sitting 6 months
  26. Torque converter stuck to engine
  27. Crank shaft sensor
  28. Transfer case over full
  29. clockspring
  30. Pesky Check Engine Light
  31. 2008 F150 5.4l timing
  32. Truck cranks but no start
  33. Passenger Side Floorboard Leak
  34. Help ! #3 Misfire
  35. 05 F150- roush intercooled pump relay and CHT sensor help.
  36. 4x4 not disengaging with solenoid hooked up
  37. Can't pump gas at full speed anymore.
  38. A/c compressor intermittently working
  39. Ac compressor replacement 2004 f150xlt heritage 4.2L Canadian
  40. Black liquid leak but NOT oil...I think
  41. Timing chain replacement
  42. Front differential mount ripped from frame
  43. 2007 F150 5.4 , stumbling, then running rough, then trans bucking? Misfire on 8?
  44. Running rough, misfiring.. couple questions.. help.
  45. Ticking/tapping 5.4
  46. 2008 F150 Moonroof Issue
  47. Instrument Cluster/AC/Shifter Issue
  48. 2007 Throttle Issue around 75 mph
  49. 2008 4.6L Heater Core Leak?
  50. 2007 F150 5.4L Hot Temp Aggressive Shudder at Idle
  51. 2005 Lariat, stalling, hunting shifts, hard starting - HELP
  52. 2008 F150 4x4
  53. 4.6 Slightly shaking on idle
  54. Leveling for 2WD
  55. 07 fx4 4r75e neutrals out above 2nd
  56. Help please - Limp Mode for No Obvious Reason
  57. 2004 f150 5.4L lean code p0171
  58. 2008 King Ranch
  59. Crank no start help
  60. 5.4L v8 Rough idle in gears and shaking when accelerating
  61. New owner of a 2008 F150 Triton 5.4L
  62. Tranny swap
  63. F150 Motor Mounts - Need Advice, Pass Side NLA, Now what???
  64. Tachometer makes a noise
  65. 2008 F150 5.4 Triton
  66. Shift tube replacement
  67. 2005 Ford F150 Manual Door Locks - How to fix?
  68. '04 f×2 lariat code p0351 help request
  69. RPM Surge After Cam Phaser Replacement
  70. Best place to buy OEM Parts
  71. 2007 F-150 Lariat - Wheel Vibration and Front End noise
  72. 2006 4.6 Triton Help
  73. Keyless receiver module issues I think.
  74. 2005 Ford f150
  75. What am i missing
  76. 07 4.6 high coolant / trans temps
  77. Clips for fuel lines at the fuel pump.
  78. 2004 F150 5.4 3v oil change
  79. 2006 4x4 Ford F-150 5.4 Triton
  80. 06 5.4 no crank no start
  81. 2004 no crank no start
  82. 06 4.2 v6 no spark
  83. *Newb* 07 f150 fx2 5.4l donors?
  84. Headlights go out when I tilt steering wheel
  85. 04/05 Bumper to late 06 F150 Hood Release attachment??
  86. Rebuilt 4R75E shifting hard while towing
  87. Fuel Tank Swap
  88. No tow package, need to tow travel trailer
  89. 04 Stalling after Tranny Swap
  90. No Power - No Codes - No Clue!
  91. Instrument Cluster Airbag LED
  92. What is this relay, fuse , ground?
  93. 07 F150 5.4L 2WD Supercrew low fuel/tank full/runs good
  94. Transmission bug
  95. 06 4.2 v6 transmissiom epc solenoid
  96. Transmission swap
  97. Anyone help me out with the name of this part 2005 f150 4x4
  98. Reattaching 2007 Rear View Mirror
  99. 2008 F150 XL 4.2 misfire
  100. Upgrade Instrument Cluster
  101. Starter intermittent on 2007 f150
  102. Transmission
  103. VCT solenoid
  104. 2006 f160
  105. 04 f150 4.2l intermittent no start
  106. Radio stays on
  107. 04 5.4l 3v p0357
  108. Check Engine Light: P0171 and P0174 codes
  109. 04 f150 FX4 5.4 3 valve making a squeal by torque converter/transmission
  110. crew cab rear doors
  111. 2004 F150 Vapor Canister Question
  112. dead truck
  113. 2005 led puddle lights
  114. 2004 5.4L 3V Thermostat Housing
  115. 285/70r18 on stock rims 2.5 level
  116. Long Term Review: 2004-08 11th Gen F150 Centric 2 Piece Brake Conversio
  117. Power mirror issue
  118. 04 F150 Power Mirror problem
  119. 5 beeps from dash area
  120. 08 f150 2wd, 4.2l crank no start
  121. Engine misfire blower only works on high
  122. What Trans is in my 06' F150 4.6 4x4?
  123. Loud sucking noise coming from engine 4.6 triton 04 f-150
  124. power steer reservoir bracket
  125. 04-08 to 09-14 dash/ digital instrument cluster swap
  126. P307 with wet coil and plug
  127. Ford f150 electrical issues.
  128. Power Steering fluid for a 2006 F 150 XLT
  129. 4x4 whining noise
  130. 2006 no crank/ no start
  131. 2k4 - stx
  132. 04 Lariat Speedometer issues
  133. How to convert a cigarette lighter to 24v USB-C
  134. 2005 cigarette Lighter
  135. Reduced Engine Power & False Overheating
  136. 305/65r18 or 295/65r18
  137. 04 Door Ajar when cold out
  138. 2004 F150 5.4 stalling out
  139. Cant get out of first gear
  140. Multiple COPS replaced
  141. 2008 F150 4 x 4 question
  142. Need Catalytic Converters on my 08 F150 - some questions
  143. PO0353 Code
  144. 06 4.6L Reg cab 4*4 leak pass side
  145. Problem with tail lights
  146. How to "rebuild" Your OEM Coil on Plugs
  147. 2008 F150 FX4 Heated mirror issues
  148. Dual fuel pump 04-08
  149. Need Help Please. Will not run.
  150. new headlights for 2008 F 150
  151. 2004 F-0150 4WD not engaging and no light on dash
  152. 04 FX4 4x4 issue
  153. PCM for 2004 Lariat 5.4l Trinitron Engine
  154. Water leak 2007 F150 4.6 intake manifold.
  155. 5.4 triton Rough idle, shaking, and popping exhuast
  156. 2008 F-150 FX4 (70,000 miles) - slight shudder/vibration when accelerating from a sto
  157. Coolant life Peak
  158. center console swap
  159. P0011 and P0021 code after timing job
  160. Engine not Running Right
  161. Remove stuck seat 2004 F150 Lariat
  162. Timing chain
  163. New TPMS Sensors Error
  164. Roush supercharger kit
  165. Temp relocation of heater core to get some heat
  166. Electric Cooling Fans
  167. 2004 Trans cooler lines same as 2005?
  168. Heater core inlet hose
  169. Engine Replacement
  170. Heat issues
  171. Lower Spring Seat
  172. Forscan info
  173. Intermittent no crank no start issue
  174. 04-08 f150 4.6 Triton to 5.0 Coyote swap
  175. 2006 F-150 5.4 4x4
  176. Replacing lower radiator hose ???
  177. Mechanical oil pressure gauge
  178. 2005 5.4 ECT Sensor - Out of Ideas
  179. help with starting problems
  180. 2006 truck Rear turn signal not working
  181. Flow Master Drone Sound Deaf
  182. Do Manual Transfer Case Truck still use IWE?
  183. Engine/Tranny surges,slips
  184. 2007 5.4 only getting 7.4mpg
  185. 2004 FX4 Front Differential leak
  186. 2005 f150 engine/tranny swap
  187. 2007 5.4 roush sc seems very lazy
  188. Lincoln Mark VIII cooling fan motor failure
  189. Who has the lowest miles on an 2004-08 F150.
  190. 2007 Lariat Crerw Cab with 265k miles. you wont believe the great condition
  191. 2007 F150 5.4L 3V Rattling and Rough Idle
  192. No turn/ stop lights on trailer
  193. 2004 4.6l starter top bolt stripped
  194. ABS and Brake Light
  195. 2005 F150 rim and tire dilema/.
  196. 2005 Ford f150
  197. After Market Running Board LED lights wiring
  198. Stuck in 4x4
  199. Accelerator limp mode
  200. Wire loom
  201. Want to add OEM Parking Assist to 2007. Looking for part #s
  202. Parking Brake Control Cable Replacement
  203. Runs rough after about 20 minutes
  204. 06 f150 tranny slip light throttle
  205. True story
  206. Air bag light on instrument cluster
  207. Ac won’t stay cold
  208. Upgraded mirrors with turn signals
  209. 2007 F150 Right front A-Pillar retaining clips?
  210. tailgate won't open
  211. 06 fl50 random no crank no start
  212. 2004 F150 4.6l rpm limited to 2000 in drive with brake applied
  213. DRIVE SHAFT SPINNING IN 2hi
  214. Cabin intake location for lysol clean
  215. Best 6-8" lift kits still available???
  216. 285/65 R20 on leveled FX4
  217. 06 5.4L Lariat
  218. Rough Shifting 1st to 2nd
  219. 05 Trans fault with o2 sensor faults
  220. 2004 F150 FX4 fender trimming
  221. 2005 F150 STX 4.6L to 5.4L swap
  222. Temp spike then goes down
  223. What’s wrong?
  224. 04 strut lift block thickness
  225. Special f150 build abs system delete?
  226. Oil temp sensor not connected to anything
  227. Oddball '04
  228. gasket, gasket sealer, or both? on differential cover
  229. Side mirror upgrade
  230. Fuse 14 issues
  231. Olm
  232. Lighted mirrors
  233. Horn won’t stop blowing
  234. M
  235. 4x4 light does not come on
  236. 04 f150
  237. Bed swap
  238. Gear swap question
  239. Is this a factory rear view mirror setup?
  240. Need help transmission !!
  241. Drivers Side Power Window issue
  242. Exhaust Gasket
  243. Pats system bypass with a relay and non chip key
  244. Getting 2019 wheels/tires for my 2008 F150 - TPMS sensor swap?
  245. starts then dies
  246. What's one of the better things you can do for the 5.4 3v to increase performance?
  247. Just picked up an 08 F150 FX4, but the external temperature gauge reading in C, not F
  248. Need a battery
  249. Get UP TO $500 OFF MSRP on Borla Exhaust Systems
  250. 4wd rear end
