PDA
View Full Version : 2004 - 2008 F-150
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219
  1. Cam/timing job needed, socal recommendations?
  2. 35's on a 2.5 inch rough country level kit
  3. Where to buy new/used timing chain cover
  4. How should a Cam Phaser look?
  5. 04-08 Ford Emblems
  6. 2007 f150 xl
  7. Anyone else have manifold gasket issues ?
  8. I am buying a 2004 F150, some questions...
  9. Ground Location
  10. Whether to buy a 2008 5.4L XLT
  11. 2006 f150 4.6l
  12. Is it 4.6 or 5.4?
  13. Leveling 05 F150 and beefing up front end.
  14. spare tire well.
  15. 2004 f150 xlt 5.4l 3v Timing kit
  16. P2197 Code Rough idle/Stalling
  17. Instrument cluster intermittent issue (only when cold outside)
  18. FLex fuel 2008-2010 question.
  19. scantool used for misfire
  20. Fan Clutch R&R
  21. 2007 F150 V6 runs rough
  22. Led pods in bumper issue
  23. Tracing low current draw
  24. 2005 FX4 Blowing Ignition Fuse
  25. 2004 4.6 Stalling
  26. Poor gas mileage (5mpg)
  27. 2006 F-150 Lariat, low beams out, high beams good
  28. 05 f150 4.6 timing chain tensioner replacment guidance
  29. Interesting Electrical issue
  30. 07 F10 Cascading issues from a simple start need help
  31. Armrest console hinge broke
  32. Exhaust Manifold Leak
  33. please listen to video
  34. Timing chain tensioner
  35. '08 F150 unknown airbag code
  36. northwest limited edition
  37. iwe broken vacuum line on driver side
  38. Fuel gauge malfunction
  39. Replacement Headlight Assembly?
  40. How to remove interior compartment console
  41. Passenger side wiring harness placement
  42. oil dipstick length
  43. Lower strut bolt
  44. 2004 Triton V8 5.4 Lurching on acceleration.
  45. Parasitic draw
  46. Deer damaged 04
  47. Brake light
  48. Starting to look Promising for 6r80 Swaps
  49. 1.5" 2008 body lift
  50. Factory Remote Start
  51. 2008 f-150 p0022 cel
  52. P0128 Coolant Temp Below Regulating Temp
  53. Yet another 4wd problem
  54. 07 Ford F150 fx4 Trans Fault comes on when engine cold and braking. Trans shift fine
  55. Front end vibration 2008 f150 4X4
  56. Idle screw broken -NEED HELP PLEASE!
  57. P2197
  58. 2007 F150 4.2 L - no spark
  59. wiring schematics
  60. Oil dipstick reading for cold engine
  61. No crank no start no gauge cluster
  62. Fog Lights
  63. Truck wont turn over
  64. Dials and lights on instrument panel
  65. Turn signals not working
  66. LED Headlights
  67. scangauge 2 owners
  68. Low revs after transmission rebuild
  69. 2004 door lock question
  70. 4x4 vacuum questions
  71. Frame ro
  72. Has anyone swapped a 2009-2013 5.4 into a 2004-2008 F150
  73. Rusty Bumpers
  74. Transmission replacement?
  75. 2008 f150 stalling out at stops
  76. i have a 08 f150 stx
  77. 2004 rear backing plate
  78. Just bought a 06 F150 Lariat but it has a few issues. Any advice on what to do?
  79. Does PCM module change mean I have to reprogram my PATS key
  80. transmission leak
  81. Need 2005 wiring diagram
  82. Tail Gate Emblem
  83. Newbie 2004 F-150 swap to 96-98 5.0 motor
  84. p1233 fuel pump driver module offline
  85. Anyone running 10w-40 motor oil?
  86. 2004 Seat question
  87. Brake controller
  88. Rear power sliding window intermittently works
  89. engine and transmission swap in 2010 ford f150 4x4
  90. Does anyone know the name of this part
  91. 04-08 Tail Light Q?
  92. Driveshaft Slip Yoke - Keyway vs. Non Keyway
  93. slow speed surging
  94. Is My Steering Rack Bad? (VIDEO)
  95. Major fuel problems in my 2004 5.4...helllp!
  96. Possible power steering issues or something else
  97. using 2v motor in 3v truck is it doable?
  98. 2005 bed bolt question
  99. Rough ide stalling - what hose is this?
  100. Damn bleeder screw...Need help!
  101. 2004 f150 PATS reset?
  102. Does anyone know what’s these are? Working on PATS system
  103. gauge cluster removal
  104. Truck will not shift out of park. 2006 ford 150
  105. oil temp
  106. My truck sounds like a diesel.
  107. Custom Cluster Question
  108. Transmission?
  109. 75-90 diff oil in rear end
  110. Advice on replacing rear axle brake lines
  111. Window regulator pulley fix (of sorts)
  112. Putting svt raptor seats in my 2007 Ford F-150 xlt. Extended cab.
  113. 07 F150 5.4 3v Cylinder Head removal
  114. F150 reduced engine power
  115. Squeaks and rattles
  116. 2008 ignition coils - which ones?
  117. strange sound during acceleration
  118. I’m Back!!!! 2007 F-150 Supercrew XLT 4x4
  119. 06 f150 led fog lamps
  120. What rear axle do I have?
  121. 04 f150 lariat weird power seat issue
  122. Clicking Noise front left... Sounds like rock.
  123. precats on a ford f150 5.4 in cali
  124. 2005 F-150 dead 4.6 - swap questions with grand Marquis 4.6
  125. p0420 & p0171 codes
  126. $500 F-150 takes on everyone in tow battle
  127. More fueling issues.... now with the gauge
  128. transfer case output flange seal replacement
  129. 2008 xlt tailgate handle
  130. 2004 F150 electrical ?
  131. 2004 f150 5.4£ starter circuit issues?
  132. 2007 f150 chug shifting at 45 mph
  133. Broken Exhaust Manifold Bolt good enough reason to junk a car?
  134. 2008 Ford F-150-
  135. Truck is bucking on occasion
  136. brake light
  137. 4X4 broken
  138. Turn Signal Issue - Please Help
  139. just saying hey
  140. Difference between SW6109 and SW6256 Cruise Switches
  141. Changed fpdm, still idles rough and stalls when warm what do i do
  142. Camshaft Position Sensor
  143. gas milieage
  144. Steering Issue
  145. Suggested maintenance on 2008 fx4 with 135k miles
  146. I will not give up!
  147. fender flares
  148. Engine replacement
  149. 04 FX4 Wheel opening molding / flares
  150. Cabin air filter
  151. Shift Linkage Cable Replacement
  152. NO Crank no start
  153. Spare tire mounted on a Bronco-style carrier
  154. 07 Adding automatic headlights.
  155. What rear end options?
  156. Check Engine Light
  157. My ordeal having a bad Transmission output shaft bearing
  158. 07 f150 air compressor
  159. Rear door panel removal 2006 SCab
  160. Speakers Front & Rear
  161. 05 f150 v6 trans issues
  162. Fuse for fuel guage
  163. what number fuse in fuse box coincides with gas guage F150 2006?
  164. Transmission Cooler Fitting Convert to Hose Clamp
  165. Fueling questions
  166. 04 5.4l 3v Strange Clicking
  167. 2004 f150 Screw fan blower intermittant stopping
  168. Parasitic battery drain and power windows
  169. F150 5.4
  170. 2005 Ford F-150- Rough idle, hard to start and smell of fuel when idle.
  171. Brake keeps truck running
  172. 05 5.4 Auto Trans issue
  173. 2007 5.4 Cylinder head removal
  174. Camshaft Sensor
  175. 2006
  176. 05 F150 Shudders when starting to move forward.
  177. Starter bolt part#?
  178. Rusted Hole In Frame
  179. Fusion key
  180. 06 Mark LT coyote swap.
  181. Serpentine Belt to Pulley Rubber Transfer
  182. Plugs, I guess it's time ........
  183. 2004 fuel tank bolt thread pitch
  184. 07 power steering issues
  185. is the 2006 ford f150 fuel relay replaceable
  186. What is this electrical part?
  187. 2004 f150 ford pickup hard to start
  188. 2005 f150 5.4 either wiring problem or cam phasers
  189. 2005 f150 5.4 either wiring problem or cam phasers
  190. need some part number help
  191. Hi
  192. Leaky Sliding Back Window
  193. biggest tire/rim
  194. P0012 & P0022 - Complete Timing Job done, what now ???
  195. dip stick tube help
  196. Getting to the bottom of our bad ac
  197. 2005 F150 5.4L strange misfire and lean/rich codes
  198. 2005 F150 4.6 - Lots of issues after fender bender
  199. Crazy bump related squeak/rattle under my dash??
  200. 2015 Coil-overs on a 2014 f150
  201. 04' F-150 Fuel Tank Drop??
  202. 5.4L 3v High flow intake manifold
  203. Haven’t posted on here in two years
  204. cruise control
  205. looking for Part number to replace all my cooler lines..one leaking.
  206. Adding the keypad unlock
  207. Cluster fuse blows when connected
  208. Former AT&T service truck
  209. 3rd Brake Light
  210. After market LED Headlights
  211. Need to replace the exhaust manifolds
  212. Bothersome rattle
  213. Engine vibrates violently when coming to a stop
  214. 2005 5.4L 3V Engine & Transmission Hot: As Good As It Gets?
  215. 04 f150 fx4 shudders when in od and going up a hill
  216. Check gauges?
  217. 08 f150 fleet build
  218. Need HVAC Control Unit 2004 F150 Lairat 4X4
  219. 04 fuel filler flapper valve gone missing!
  220. 05 5.4L 3V Cam Journal Cam Cap Minor Score
  221. 2018 Raptor Rims on 2007 F150
  222. 05 F150 hd
  223. can i move my air bag sensor
  224. 2007 F150 AC not staying engaged
  225. P0020 and P0021 issue??
  226. Which 2017 Raptor Parts Will Bolt On?
  227. Strange AC buzzing/grinding issue
  228. Raptor Conversion Dilemma involving Wheels
  229. Front end Vibration
  230. Blinker problems with led tail lights
  231. 5.4l 3v - Reman or Rebuild?
  232. 2004 5.4l 3v Camshaft scoring
  233. Rear bumper interchange
  234. 07 F150 battery light after new alternator and battery
  235. has it been done?
  236. Motor Swaps in CA??
  237. Fiberwerx 2017 Raptor Conversion?
  238. Starts, but won't run
  239. Ford 2007 Pillar post
  240. 2004 F150 5.4 160K miles, a/c working poorly
  241. P0345 p0349 camshaft position sensor bank 2 help
  242. 04-08 f150 Skyjacker 6 inch lift CV angles/ Upper balljoint angles
  243. Fender Flare Thread?
  244. To Raptor...or Fake it?
  245. Mark LT will not rev past 2900rpm
  246. Grill differences between lariat/xl/xlt?
  247. 06',5.4 3 valve
  248. Anybody Replaced their Radio Antenna?
  249. Chugging truck
  250. 2wd front hub/rotor change 04-08
