Transmission Cooler Fitting Convert to Hose Clamp
I have a 2005 5.4L with the factory super cooling transmission fluid cooler. The transmission line comes from the radiator to the cooler and then out the cooler back to the transmission.
I want to convert the lines in and out of the cooler to allow for the installation of a B&M cooler and need to know the thread information.
I cannot seem to find any information about the size, thread, pitch, etc. of what these fittings are and images are attached below. It takes about a 7/8" wrench to remove, so I'm thinking that these are some sort of 5/8" thread size ... though I suppose they could be a metric, as well. But, I cannot for the life of me find anything. All of my searches for the transmission line fittings just point me to the ones that go in and out of the radiator. Ugh.
They aren't tapered or flared. Just straight threads with an o-ring (as you can see in the attached).
I'm looking for something like this for the conversion:
Does anyone have any information about what these threads are?
Thanks.
Thanks.
For those of you scoring along at home, those threads are 3/4"-16 threads. They are fine SAE or UNF threads (same thing, different sources will use different terms for the same thread)… no taper, no flare, not NPT or any other tapered pipe thread.
Now the trick is to figure out some way to get a 3/4"-16 male converted to a 3/8" ID hose … and a 3/4"-16 female to a 3/8" ID hose. Ugh.
I think this should work: 3/4"-16 UNF to 3/8" NPT and then 3/8" NPT to 3/8" ID hose barb:
