View Full Version : 2004 - 2008 F-150
- Fuel Pump bad? No start, Need advice
- Do i HAVE TO Pay for TSB service ??
- 2012 f-150 crewcab Door Panels
- New issue discovered after resolving old issue
- Steering shaft
- Speedo is off by 19 mph
- My "new" 07 lariat!
- Tailgate Is Misaligned
- 04' f150 4x4 5.4 3v swap engine for a 2010?
- Break light stays on
- 2004 5.4L 3v F150 - Front End Vibration/Brake Grinding sound
- Dies Out No Crank Theft Light Engine Compartment Clicking
- Airbag Light On? Two Common Causes & Fixes
- Rust spots/paint peeling on bumpers
- Wheel well to wheel well side bars on a supercab?
- Painting FX4 grille advice
- balancer install (harmonic install).. need some tips.
- no air bag light coming on.
- 05 Brake pedal goes sideways?
- Centric 2 piece bearing failure
- Battery or Altenator?
- Another a/c question and e-fans
- 5.4 Eaton supercharger on a 4.6l
- How to disable alarm. Don't want it
- VCT Solenoid ????
- fail to start anomaly
- Headers, Headers BLAH!
- Another TPMS question about swapping wheels
- Need your help PLEASE!!!!!
- Normal or should I get it checked?
- King ranch seats
- A/C Temp knob
- Turbo Talk
- beeping sound
- Ball Joints Replacement Cost?
- Need some Timing Help
- crazy operating fuel pump
- Napier Give-A-Way at AutoAnything.com!
- I need help with some ideas I should do with my truck
- 15% OFF & Free Shipping!
- westin max winch tray
- 08 XL V6 has weird a/c issue
- 2008 f150 fx2
- Engine Running like crap after degrease
- Bye to the 04-08 section
- 2006 In Dash Cup Holder Repair
- Time to say goodbye to you guys....
- Engine problem
- No Start Issue - Could Really Use Some Help
- center console cup holder solution
- Truck just died on me.
- 2007 Harley ?
- Help keep your cargo safe (pics)
- wheelskins cover, sand or oak?
- '07 Supercrew 4x4 XLT - Tire Size
- Please help me find the issue
- My 5.4L spark change
- ticking/poor mpg
- Check guages
- Seating COP connector?!
- 05 f150 5.4 code p0012
- Need help finding trim piece for my 2008 single cab
- Programing a new remote....
- Trailer hitch
- starting issue
- Need 7 pin trailer plug for my 04 f150
- Underdrive pulleys
- Scraping and Redoing my Exhaust....suggestions?
- Mechanic Results of possible manifold leak....
- Programming FOB's across years?
- Bought a Used F150 has engine loss of power and rough acceleration
- Check your drive shaft!
- 04 F150 Lariat
- Loud click when turning left.
- Great price on complete Ford timing set
- Door Lock Issue
- Please Help 2007 Cats are plugged.
- 2005 5.4 3 valve ticking
- My A/C sucks!!! 2007 4x4 SCAB XLT
- ABS coming on when dry / not sliding
- Brake pedal
- Daystar Upper Dash Panels (04-08 F150)
- 2006 4x4 hissing from passenger side
- Potential 05' Supercrew buy today!!
- Doing ball joints what else should I do?
- Big loss of acceleration ,,,I'm stumped!
- Suggestions for code scanner
- 2004 5.4L 3v F150 - Clicking sound .. diagnosis?? No idea.. need some help
- 2006 5.4 Codes P0345 P0349
- 05 f150 transmission problems
- New to site need some help
- Relocating FPDM
- Lean codes P0171 P0174 need suggestions
- 5.4L 3 valve
- 5.4L 3v Camshaft Phaser Knock Noise Fix
- Which UCA to get?
- FFV Question
- Triple Gauge A-Pillar Pod
- 2013 Chrome wheels on a 2005
- Front differential leak...Pinion seal?
- New to Me Maintenance Schedule?
- Rebuild 5.4 or new F-150? Opinions appreciated
- Changed my VCT Solenoids on my '04: My results
- Lets talk towing
- How do I say...FUSTRATED!
- Leveled 2wd Scabs
- Driver's Side Floor Wet - Can't find source of leak!
- Front suspension
- Steering wheel controls
- Swapping out the rear seat in an '06 F-150 SCab
- 2004 F150 Rear Ended, Need some advice
- 04 F-150 FX4 Front driveshaft spin in 2wd?
- Steering wheel groan
- Truck wouldn't shift into 4x4 this morning
- Wheel-to-wheel nerf bars for my 2005 black FX4
- Looking for Ideas about Leaking Freeze Plug
- Which truck do I have?
- my truck and its problems.... couple questions.
- pulling my hair out. '05 F150 5.4
- Blue LED or Blue HID
- 2nd plug change on 5.4 3v Questions
- 2004 F150 Intermittent starter issue
- 04 Gauge cluster,Pwr windows, Ac, radio.
- Oil????
- Atlanta Area Help
- MAF signals six wire
- Need help. turn signals won't work on newly installed tow mirrors
- Please help Lisle Tool Fails
- Hauling a canoe?
- brakes pulsate sometimes and abs light is on please help
- Keep or Trade
- '06 FX4 Tranny
- 2004 FX4 SCREW Restoration???
- need help/ideas for my 05 F150
- Need some FX2 parts, HELP!
- SP 515 Spark Plug Gap
- Odometer Light Works, but no readout
- Please Help, My Gryphon Tuner Froze Up On Me!
- Spark Plugs Changed
- Retro+Raptor-style lighting (pics)
- Help with interpreting codes
- Picked her up from the body shop today!!
- If you could change anything about your truck...
- AutoAnything's 35th Anniversary! 1 Deal A Day for 35 Days
- F150 emblem sizes
- 5.4 sounds like a diesel.
- Exhaust suggestions
- Airbag light is on. Should I pull a fuse?
- limp mode
- Got the replacement rims on. My shake went away!
- Window regulator crew vs ext cab
- Power steering line fit-up
- Little Help please. Rubber doohickey thing.
- magnefine filter install, problem maybe
- Just ordered the SCT X4 tuner and SB intake!
- New '08 4x4 owner,misFIRED UP :(
- 2006 FX4 4/7 Drop Question
- Water
- Alignment after leveling
- New '08 4x4 owner,misfired up :(
- Strange Burning Rubber Smell
- Suspension lift
- Dreaded spark plug change on 2007 5.4L
- Location of fuel pump relay/fuse???
- Show your 04-08 with 4" lift and 35s....
- New Member with Bilstien 5100 Questions
- Can't Decide On New Rims
- 2007 F150 Rear Brakes
- P0059
- miss fire
- What year motor and transmission will work?
- tranny hunting while coasting
- thumping under decel
- truck shutters when put in reverse
- 4 wheel drive problem
- 2004 OEM Intake Mod
- Replaced battery and it will not start but does crank
- [WIP] Custom Guage Install, 5.4 3v, 4R75E (Oil Pressure Guage and Transmission Temp)
- turn signal came out of socket
- Go Rihno Light Bar Question
- King ranch seats in EXTENDED cab 04-08
- anybody have a 6" lift with 35's
- limited slip shudder
- Help me choose some upgrades
- Help!!-need help/advice changing Upstream passenger side o2 sensor 2005 f150fx4
- 18" mb tko--help w/ tires
- 6spd conversion..
- Fuel gauge problem
- rusting rear wheel wells
- No reverse- 4r75E-W?
- P0420 Code
- Anyone know where I can get these ?
- FX4 Flareside Decals
- 2004 FX4 bent axle question!! Need a good answer ASAP
- Custom Exhaust on my Harley
- My experience with the dreaded FPDM
- Truck thinks its in nuetral?
- Where to buy Saleen Radiator?
- Truck still misfiring at wot
- 2008 f-150 xl
- Infamous spark plugs.....
- 2004 f150 power fold mirror mod issue
- Just installed 2.5 " leveling kit , what about alignment??
- Just Bought '07 FX2 Sport. 5.4 Triton seems slow.
- Should I be afraid of the 2004 5.4l Triton...
- Leveling Kit install?
- P0171 Lean bank 1 Code
- Mechanics in Northern VA
- Shudder When Taking Foot Off The Gas
- Has anyone tried the DIAMONDBIRD MOD??? throttle adjustment mod better response
- Power window problem
- 2007 F150 FX4 Highway Speed and Braking Vibration
- My story of a passenger side water leak.
- Who here has the lowest mileage 04?
- 2006 F-150 OEM seat covers
- New shoes
- 2004 Lariat brake lock actuator / interlock
- Got lift & tires on
- 2005 fx4 roaring while pushing and letting off gas
- 06 ftx stalling
- how much will this cost me
- Just bought a new-to-me 2004 FX4 SC .. what to do to it maintenance-wise?
- Codes
- Stainless Steel Brake Lines
- 2004 ford f-150 driveway tank removal and fuel pump replacement
- '05 gas gauge problem or fuel pump?
- HD lights on STX?
- Rim and tire size
- Anyone got LT Headers on a 4.6 2WD?
- 2008 F150 FX4 - 4x4 problems
- Running Boards
- 2007 5.4L: Edge Evo/Bank Intake & Monster Exhaust Advise
- Need some Insight on front DS and CV axles
- So long, Stealth. Hello Stealth!!!
- 2004 F150 SuperCrew Cab 4x4 XLT. V8 5.4L with 130,000 miles a good deal?
- Metal ting sound about 30 sec after start and
- heated mirrors
- My 2006 FX4 Build
- Help with oem towing mirrors for '05 XLT SCAB
- exhaust manifold quotes
- O2 sensor driver side before the cathow in hell
- Anyone know this trim part number or where i can find it?
- Is it just me?
- Truck in shop
- 200k mile maintenance
- Transmission Fault/Flat Towing
- Bilstein 5100 AND AS 2" spacer??
- 4WD shocks on 2WD with 3" Block
- driver door problem, thinks its shut sometimes.
- Need Plug/COP Opinion
