View Full Version : 2004 - 2008 F-150
- A/C acting up- Ive tried searching
- VIOLENT SLAMMING AND SHUDDERING during Acceleration! HELP! (04 FX4 SCREW, 92k mi)
- Plugged Vacuum Line ...From The Factory?
- tinted my tail lights
- It's finally finished(For now atleast)
- Some new paint :)
- All cleaned up, and some exhaust vids.
- 2007 FX2 5.4 Needs a new engine WTF!
- Can a US member compare these prices for me ?
- Overhead Sunglass holder broke
- I have one doubts i need aid
- Viair Dual Trump Air Horn Install help
- Need help and need help fast
- lights behind grill
- Look what came today!!!!!!
- Quick question about DTC codes and scanning for them on a 2005 f150
- Lifted 04 on ebay
- Center Console Gun Mount
- O-Ring on Dipstick
- So the plugs are soakin - Does prem gas, seafoam and Lucas really matter?
- Another Weird Popping Noise Question...
- Saleen 23" wheel offset... confused
- looking for flareside bed
- good deal??
- High Pitch whining noise
- a few changes
- Got some new stuff.
- Bed Caps
- Noise from rear
- Readylift block
- Got a new truck
- Radiator damage
- CEL with code....P0420
- Painted Frame
- Painted Brakes
- To Paint the Wheels or Not? Give suggestions!
- Search all of craigslist!
- rear lockers
- Anything we need to know for brake change ?
- Couple pics of my new ride - 2008 F150 SCREW
- Broke a Spark Plug POS
- SCT Xcal 3
- What R U doing 4 GOOD MPG?
- Went shooting, and a little excitement for the truck
- Truck sputtering and bucking when excellerating
- Radiator issues........ help?
- bambi mod question
- WTB - Jack accessory kit
- Cam phasers and injectors...
- Just changed my fuel filter blue clip
- just got back from ford
- difference between 05 5.4 and 08 5.4
- New Alternator 200amp
- 4wd not engaging!
- Did my battery short out????
- New Look, on the inside (pics)
- P0171 and catless
- 2007 F-150 FX2- Driving in snow?
- Will 285's fit
- 3 valve junk?
- Need help. 2006 f150 lariat
- What should I do next?
- it is finally paid off!!!!
- Critique my truck
- 05 f150 screw stalls
- My 06 F-150 FX4
- Paint Bubbling?!?
- NBS lightning concept creation
- 2004 stx - Selling Price
- Efans from 2010 on 04-08 5.4?
- FORD emblem
- Won't rev up (04')
- Brake Change Miles
- Smoked Glass
- More lights!!!
- RE: Which vehicle?
- New accessories suggestions for 2005 F150 4x4
- Ford racing hot rod cams
- Heated Side View Mirrors
- What's wrong with my 05 F150??
- auto lights not working
- Thank you F150online Members
- What was this guy thinking?
- Need some help on what to do next? and opinion on grille
- Question about Harley Headlights
- Motorvac vs BG Fuel/Air Induction Service
- Picture of passenger airbag sensor wire
- Would this look good?
- small shutter from stop: Limites Slip axle?
- Multiple misfire code ???
- Overdrive and MPG's???
- Truck Wheelbase vers Trailer Length
- 4.6 plugs
- New to forum, need help
- Need pics of Mirror Plugs
- Emergency brake indicator sporadically appears during driving. (04 FX4 SCREW)
- 2004 4.6; Shaky idle, engine light and possibly a vacuum leak
- Window Regulator Help
- A/C Drain TSB Completed Floor Still Wet?????
- If your Trucks "Wrapped" let us see it.
- Just A Heads Up For Any Of You In KC
- Need Tires for All-Season & Towing
- Is he crazy or are these trucks worth this kind of $$
- Headlight / Electrical Problem
- Should I re-gear?
- Help!! Question about controls on steering wheel
- Mods and fuel mileage-
- Slow Throttle Response
- New Tires, Small Problem
- fog lights behind the grill
- I am Out..
- Pics of a two wheel drive jacked up
- custom center console insert
- help with pictures!!
- Another successful 5.4 3V plug change!!!
- new Harley wheels on craigs list
- Paint chafing fender flare problem solved?
- Center console access
- cam phasers/ warranty and ford...
- STX rear power windows
- 4x2 2004 F150... slippin' and slidin' at the boat ramp...
- Mechanics in Houston for Efans?
- Tire Pressure for Goodyear Silent Armors
- Transplant 09-10 SCREW Seats into an 04 SCREW?
- Crap! My A/C is out!
- 3.73 to 4.10
- Leveling Kit Installed!!!!!
- Bummer - first meaningful rust
- 05FX4 gear selector problem
- to swap gears? or not to swap gears
- key wouldn't turn
- 2006 f150 POWER WINDOWS, RADIO, AND CLUSTER GONE DEAD>
- UCA Replacement Question
- Please Help. Problems filling up and with fuel gauge
- fuel guage/sensor problems?
- NCSU's HID Retrofit Headlights...
- seat belt alarm - with a twist
- Help! Squeaking coming from rear of truck
- New Guy
- Let's see the Silver ones :)
- Quick Question
- Fender flare question
- monroe quick strut
- What do ya think?
- You can never say you're 'finished' with mod's
- :help::help::help::help::help:pleas some one help me, i have give up
- Troyer or Flex-a-lite
- Josiah sell his F150?
- Light Bar Build
- leveling kit and new tires
- trans and rear axle fluid capacity?
- Who said V8's can't sip Fuel?
- weird window problem
- My new tires
- 305's Rubbing
- 2004-2008 f150 - best model year - need help !
- Got my 5100s installed!
- Red Third Brake Light?
- washers
- Help: Rubbing with Toyo MT 33" & 2.5 Leveling Kit
- Bed Lights
- Help! What to buy?
- Headlight/Foglight bulb upgrade
- Some new mods
- Help me
- Help with new mods
- Need help with leveling kit install in Dallas Texas
- Rear axle fluid change opinion yes or no
- New to the site
- Keypad keyless entry....
- for people with body lift and lvl kit...
- Truck won't Start
- Window squeaking
- OEM 17" rims
- Power tailgate wiring. NEED HELP IMMEDIATELY!
- Squeak squeak squeak down the road..
- A/C turns on but won't blow any air!
- Help with fuel filter removal tool
- Finally lowered 2/5!
- What is this?????
- Cats going bad!!
- Sell me a truck!
- 2004 f150 triton 3v spark plug removal
- Dealer only bolt? 31$!! Any other options?
- OBX pictures
- Mag-Hytec Transmission Pan?
- 5.4 Rod Rap
- ABS and Brake Light Coming on Randomly!
- Damnit...bucking again...any ideas?
- Need a New Front Bumper...
- RIP Big Moosie
- Air bag light flashing a 3-3 on my 2006
- Please help...somethings not right
- Gargle Noise After Truck if Turned Off???
- Front brakes SMOKIN...
- Screen Print on truck??
- Fuel Filter Blue clips
- Good deal on a good grill???
- No power?
- Bought some stuff!!!!
- Happy fathers day
- 152,000 miles = time to change plugs
- 06 F150 tires and lift help
- F150 scam lol
- Wiper Blade Inserts
- UDP, Efan, Gryphon and XXTRME frustration!!!
- Ranch Hand Brush guard
- Newbie here
- Used Troyer xcalibrator 2 tuner?
- Help with tires and lift please
- 06 F150 Used
- Carbon Fiber Interior Pieces
- Few pics of my 05 FX4 Screw
- '04 screw 4x4 roaring from rear tires
- EPA rating vers reality
- Great News !
- removing plastic gas cup?
- Best place for Misc Parts
- Whine from the Motor....bad alternator?
- Airtex fuel pumps? Replacement on 04 F150
- Troyer stage 2 to Stage 4 supercharged?
- PHP sticker
- oem running boards: clips broken cant get bolts out.. Help..
- Whose Put on Their Own Body Lift?
- Value of my truck...
- New Alternator-still low battery?
- 06 F150 wont start!!
- Paint to Black Handle Bucket Covers (pics)
- Lift/Leveling an 2wd 07? How high in front?
- Ford emblem
- Removed Stickers....Now What?
- Final answer on rear shudder
- New Electronic Mod to my truck
- ? For those with gear change
- noise from the tranny area
- Parking Brake Removal
- Looking for a few things (bumpers, wheels, grille, etc) where to buy?
- OEM Back up Camera on rear view mirror????
- OEM 5" oval step bar misadventure - Need mounting hardware
- What E-Fans do you have?
- Help on purchasing a 2004 f150
- Bad Vibration on Accel..
- What is this for?
- vents behind backseat
- Hella Black Magics?
- AC wire for electric fan
- Bed Extender mounting bolt
- Paint worse than I thought
- Reverse Lights....D.T.R.
- HID Help Please
