View Full Version : 2004 - 2008 F-150
- Water-3rd brake light
- Help I cannot make a decision
- Power Steering Return Hose
- 2007 A/C wont switch to defrost?
- Chugging on acceleration...HELP
- What The HECK Is This!?
- 2007 STX New Owner
- Replacement plugs
- Truck wouldnt start, related to factory amp/sub
- What back spacing
- PTM'd Grill Guard
- 2006 Ford F-150 AC Vents Swap
- Need Some Opinions, Truck Is Crap
- KC Autosound?
- Rear Pinion Seal Seeping
- Stuck on 4X4 low
- How hard is it to change the starter?
- Anybody ever paint your wheel wells?
- New to forum and i need help
- 2006 Ford F-150 SuperCrew Tinting
- #91 Nitemare Lives !!!!
- keyless-keypad entry
- Good Deal or Not
- My "new" 07
- transmission issue
- I think I'm done! Pics!
- New '05, suggestions?
- Changed Master Cylinder, now truck won't start?
- Taking the Plunge!
- New mirrors for the truck!
- Replacing COPS
- Power Windows Problem
- Might as well share.
- 2004 F150 Center Console shifter cable boot end
- Trans issue?
- new truck. need some info
- Rough cold start.
- 08 lariat, auto unlock
- Towing a 5th wheel camper...?
- Liner-X Project
- New toy. Wife's head is still shaking...
- getting my truck ready for a trip
- 4x4 not working
- 2006 4x4 - AAL or reduce level kit size???
- 65000 Today
- Found a Nice 05 at the dealership need opinions
- photoshop for me please???
- Build/Project thread for my SCrew
- Which level to go with 2" or 2.5"???
- My "new" 2007 FX4
- Spark Plug Upgrade
- HELP.....Truck not starting!!
- How to replace pinion seal 2004-2008
- Misc Cowl Part
- Brake Upgrade
- Brake Pads and Rotors
- Good shop for gear installation in OK, N. TX, or S. KS area?
- Ordering OEM Ford parts from dealership/online?
- Dash Lights
- Converting to power folding mirrors
- Truck needs new plugs.
- Anyone used this eBay sourced 2008 FSM?
- 06 F150 no start issue and quick and ez fix
- Do I need relay harness for HID for this truck?
- HELP!!!! 05 F-150 Oil Pressure
- Any Ford Service Techs here?
- Thinking about getting a New Truck
- Heartthrob exhaust
- flex
- Misfire
- BullBar for my truck
- Summer 2012 Update w/pics
- Just bought 04 FX4!!!
- Identifying 3 valve engines
- Child Car Seat Restraint Lower Anchors for SuperCrew trucks
- Can only start my truck with remote start, key no longer works
- Rear Bumper plastic step pads
- OBX ups and downs
- Hello, fixing soft brake pedal question.
- '05 F150 mold growing in vents! How to get rid of it?
- Question for those w/ On-board air
- Facelift for the 2007
- Windshield leaking
- rear axles banging in the housing
- Pics everyone has been waiting for n mods
- Differential cover leaking
- 4x4 Check Valve vacuum Question
- Nfab step bars
- Rough idle on 4.6L
- Black Ford Emblem?
- Painting Front Wheel Wells?
- New engine for 06 5.4
- Putco vent visors
- Ordered some goodies today.
- Bestop Supertop
- new look thought i'd share!
- Straight pipe?
- Looking at F150, Need your opinions
- Weird electrical issue
- Nitemare font ??
- Bad "o" sound from f150
- My Ford is no more
- Dynomax ultraflow x 17553 . Carefully.
- How much are upper ball joints?
- Where to get 4.56 gears?
- 2006 F-150 Alternator died, Now won't shift
- New To Site. Tranny Issue 2004 F150. Advice Please
- Cam phasers
- De chromed my truck and add some more stuff
- code p2006 2005 fx4
- Engine Moan and Exhaust Smell in Cab
- Stock 20's painted all black?
- In need of stock radio/CD/MP3 for 2007 F-150
- Where can i get Foose F-150 Stripes?
- How to Remove and Paint Lower Bumper Grille and Surround on a 04-05
- Questions about my Roush F150...
- 2006 5.4 Cylinder Head Temp Increasing...
- Quick question....
- Need paint ideas!
- Had an awesome 4th O' July!
- Anybody know where to get a "DRY" air filter
- Thinking of entering a truck pull
- New Shoes - Finally KMC/Nitto
- Control issue
- Blacking out behind lenses
- Driver Power Seat Won't Work
- 2007 Lariat F-150 Odd Power Window Behavior
- 5.4s that have plug issues
- 2006 F150 STX 1 of 250 Special Edition Stepside
- Need your opinion on PTM handles and mirror caps
- strange sound, can't figure it out
- Annoying Door Chime
- Opinions wanted. New front end make over???
- changed sparkplugs now have a idledown issue
- Need some help on tranny linkage on v6 with body lift
- Vibration at idle, cause?
- Steering feels loose, cause?
- Broken interior piece?
- Cracked Exhaust manifold Need Advise
- HELP! I have a fuel system issue.
- All Door buttons wont work, radio wont turn off...
- Truck dies while stopping w/ AC on
- Rattle while throttle is applied?
- Harley heads installed!
- To those with e-fans, a few questions...
- Custom 8.5x32 Travel Trailer
- Outer tie rod
- Windows Inop With Driver Door Open
- Painted Rear Axle
- Opinions Wanted: Trade an 07 F150 for a new Taco?
- Deciding on a hood. Help
- Picked up a King Ranch last month!
- Cruise Control No Go
- new pioneer radio
- rear end shake
- Blend Door
- 05 50 MPH shake
- Plasti dip'd bumpers 06 f150 xlt
- HVAC Fan noise
- Please help. Need to know how to adjust column shifter
- Non-LS Diff fluid?
- 2wd leveled up question
- power mirror problem
- Tires for 2005 F-150 Supercrew 4x2
- Please HELP!!!! still running rough
- fan speeds only work on 3 and 4
- 08 f150 heater/A/C temperature control...
- What's the correct A/C pressure?
- Boondock Bumper ...Install or Sale ??
- 5.4 Belt issue
- First Truck = First Trip = Mileage Report
- Spent some time detailing:)
- truck overheating?
- I need some suggestions....
- 4.2L V6 Engine Swap
- Tailgate Handle Disassembly
- Painted Saleen grille, anyone done it?
- Saleen grille installed
- Brake Rotors Re-surfacing
- Radio wont turn off
- what to do??
- Time to tackle the stereo...
- ABS Light
- Check Engine Light On 2005 F150 4.6L Eng.
- Post your silver f-150
- Jake's Build Thread
- Heater Core Bypass - Which hose to install valve on?
- Panel lights
- Leaking exhaust manifold
- Did a Little Work With a Rattle Can
- Bad Cam Phasers 2005 F150 FX4
- 2004 5.4 spark plugs
- Will a 2010 exhaust work on a 04?
- Replacement Console Latch
- Hardtofind - BLACK wheel nuts
- Aftremarket Fuel Injectors
- That's one clean F150!
- Had the spark plugs done on my 5.4 3v today...dun dun dun
- Picking up 2008 Lariat this week
- Replacement overhead bins?
- Need help wiring signal mirrors
- 2" Inch lift on Supercrew Pics?
- Anyone else have rust on their brake booster?
- darrylschndr
- Help with F-150 Going into 4x4 Lo by itself
- Which Spark Plugs? 2004 FX4 5.4Lt
- Where to buy flareside tail light trim bezels?
- Help Cracked a wheel, suggestions?
- Ford Service DVD: PDF problem
- 2007 XLT Compass Module pinout
- 89 octane non ethanol
- Best way to repair dent (cut) in rear fender?
- 09 step boards on 05
- Possible bad rack and U joints?
- Buying 2008 F-150 HD 105 anniversary
- whats it worth ??
- no 17s?
- motorcraft or champion replacement plugs
- door ajar light stays on F-150 STX
- Engine hesitation and hiccupping at cruising speed. Code P0340
- window tint
- Rev Limiter Setting?
- What should I look for?
- Put in a 2.5 hbs leveling kit,,, now the front is too high
- How often do you change anti freeze ?
- Windstar Fan Install
- Lighting Questions
- opinion needed rack and pinion or inner tie rod
- Interesting mirror find on ebay
- Grinding front left end
- Some New pics
- cooling fan clutch
- 1 year anniversary
- OHM reading help on a sensor
- Cam Phaser Lockouts
- ABS Sensor Question
- 102K miles, time for suspension repairs..
- f 150 2 wheel drive tire size
- The Dark Knight
- Pretty Cool Pic of the Truck
- Engine Moan / Growl Issue on 5.4L
- raptor take offs installed
- Long trip pretty impressed, mods n a few questions
- Truck Recall?
- First repair to my 06
- Backup sensors
- SCT issues!! PLEASE HELP ME!!
- vibration in 2004 f150
- Complete partout
- wobble / bounce in front end
