Questions about my Roush F150...
I recently bought an 06 stage 3 roush f150 with 55k on it and I have a few questions. This isn't my first f150 but my last one wasn't supercharged. At idle, my engine shutters a little every once in a while which I know is normal for f150's. I was going to try to clean the IAC but I can't seem to find it! I can find it on my dad's 05 but I can't on mine. Where is it? Also when I'm driving, if I'm going around 60 mph and let off the gas, there is a brief vibration that lasts for about half a second. What could that be? Lastly, as far as maintenance, is there anything special I need to do with a supercharged truck when it's serviced? Thanks for your time.
The iac is nonexistant on your truck....
Primary routine points of maintenance that are a must on your truck are.....
Cleaning the throttle body
Cleaning the maf with maf cleaner
Changing the fuel filter
Changing the sparkplugs ar 60k and i see you're at 55k.....theyre a PIA....
If your drive shaft is the slip yoke style it may need to be lubed possible cause of the vibration
Link>>> https://www.f150online.com/forums/articles-how-tos-119/
thanks for the quick replies. I used to be a member on cumminsforum and it took forever to get a response! Anyways, It's a completely stock set up like it came from the factory. Roush's tune and everything. I've read that their tunes suck.
Link>>> https://www.f150online.com/forums/articles-how-tos-119/[/QUOTE]
I tried the link and it took me to a page full of articles and I couldn't find one about this. What exactly needs to be lubed?
I checked too and its not there....
the spline gears need to be cleaned and relubed with motorcraft x8 grease....
you could also be experiencing a ujoint that needs to be changed also....
