Put in a 2.5 hbs leveling kit,,, now the front is too high
Looks like crap, drives me nuts every time I look at it.
I read on this sit 2.5 should be good. I had a spring in the rear crack off so I had that replaced since then it sits lower on that side.
Whats the best way to fix this cause its driving me nuts.
Blocks in the rear?
Blocks in the rear?
I ordered my leveling kit and add a leaf right from their ebay store.
http://stores.ebay.ca/AUTO-SPRING-KI...id=p4340.l2563
Hearnoevil, what year is your truck? I have the exact same kit on my '05, and it sits perfectly level -- all four corners measure exactly the same from my garage floor to the bottom of the fender flares above the tires.
If you have an '06+, that would explain it, as 2.5" is too much for those years.
