View Full Version : 2004 - 2008 F-150
- Vibration under floor panel while driving on my 2004 XL
- Check Engine Light: Code B1484
- Anyone out there still doing Nav Radio reprogramming?
- My '05 (build date is 12/17/04)
- 2006 lariat wont crank. Changed battery and starter
- Fuel pressure data?
- 04 F150 RPM Surge while driving
- 2007 Headlight switch wires
- 05 F150 hard to start, rough idle, smells like gas, Help!
- Engine Swap Kits?
- 5.4 2005 f-15 low compression
- P0446 EVAP Control Vent Circuit
- Bilstein leveling shocks installation problem
- Windows (again) Need Advice
- Front fender liner mod?
- What is this Vacuum line?
- Swap 2005 Lariat Seat Base from Driver to Passenger?
- LT headers, Cats, & O2 sensors
- Rearview Mirror Question
- New Seat Covers
- Heater A/C issue
- Front Wheels Not Straight
- Truck won't start - turned off while driving
- Newbie needs help
- Parking brake only works in reverse
- Got DTC P0325 today
- Odometer shows nothing
- Is this phaser tick?
- Trans fault/od light flashing
- 2004 fx4 Weird electrical problem
- About to Replace Struts and...?
- 2005 f150 idle/stalling problems
- Overheating issue
- Misfire And Not Sure What To Try Next?
- How much for repairs?
- Climate control degrees range?
- Auto locks and brake lights
- Difficult to Steer
- 2004 std cab xlt seat options
- Oil Leak On 07 4.2 V6
- Keyless entry will not unlock but sounds like it wants to
- 2008 4.6 problems
- Broke a leaf spring today. Options?
- Missing door plug?
- How levelling spacers affect hitch ball height?
- Rim/tire question for noob
- 04 Scab gone replaced with FX4
- Popping sound --ball joint????
- Help me decide with pics!! Tire/lift- combo
- Transmission
- My knob fell off
- Flowmaster American Thunder Cat-back for the 2009-2014 F-150 w/4.6L, 5.0L, or 5.4L V8
- Trottle position sensor
- Help on my 2004 Ford F150 5.4v
- Lighting issue - brakes, turn signal, headlights
- anyone running Billy Boat cat back exhaust?
- CEL flashes 8 times in the ON position only
- 2016 wheels on 2007 xlt
- Whiney engine
- Bad Cat or B2S2 Sensor
- '05 5.4L Shooting codes P0171, P0420, and P0430
- headlights
- 2006 wont start occasionally
- Looking for Ford Mechanic? (Staten Island NY)
- 06 F150 shudders and slips starting in all gears
- Charging problem
- 2004 f150 fx4 gas gauge problems
- Horn muffled and weak
- 06 F250 5.4 Wrench Light, No Spark, No Start.
- 06 f150 rough idle when warm
- 2008 F150 tapping noise
- Low beams and high beams not working, but flash to pass and DRLs are
- CHT Sensor
- Missing under load, false overheat, radio going crazy, no codes thrown
- Back in the saddle......
- truck dies when warm
- New into the f150 gang
- Power steering line schematic
- Hesitiation when engine is cold
- 2004 5.4 v3 crank but no start!!!
- Leaf Spring Upgrade
- Electric fan controller breakthrough!
- 04 F150 wire question
- Horn gets loaded with water
- Is There an Outer Rear Brake Pad Direction?
- The Dark Side of This Country's Love of the Ford F-Series
- 2006 5.4L Rough Idle
- 2007 f150 xlt clock spring air bag question
- 2006 F-150 P0193 Fuel Rail Pressure High
- New here, Please help! Not sure where to ask a question???
- '06 F150 +12v switched power source
- fuel odor
- Overheating Issue
- Oops, I used Brake Fluid in my power steering reservoir
- 04 dash removed for blend door replacement???
- 2005 f150 no start / electrical issues
- Inexpensive roof rack for 2004 f150 super cab
- 2004 lariat electrical issues
- AC blows hot air on driver's side
- 04 5.4L ignition problems
- Cruise control nightmare
- 07 Ford F-150 fx4 5.4
- Fuel gauge issue
- Engine swap
- 4WD Issues
- AC Compressor not working all the time - 2005 5.4l XLT
- Leaf spring creaking woes
- Has anybody added factory steering wheel controls?
- Park brake light stays on!
- Center Hub Cap Falls Off
- Car seat question
- Can I cut a 2003 rear bumper to fit my 2006 f-150?
- Driver's door instrument panel
- More wheel weight or better aerodynamics?
- Rough running 5.4
- 2004 4.6 engine knock
- codes p2126 p2164
- Air conditioner woes
- Paint Job
- tires
- Mismatch spare tire question
- 04 f150 Visteon drive shaft ujoint, Needs full replacement
- life expectancy of stock cats
- 2v chain tensioner arm fit 3v 5.4?
- 04 4.6 to a 05/06 4.6???
- Questions on Aftermarket Paint Job
- LED Ambient Lighting
- ReAwakening a '05?
- Cluster/Electrical Problems
- 2007 4.6L spark plug question
- Fuel Filter
- Gearing info mpg / rpm 4.10& 4.56
- 2004 f-150 4x4 front shocks??
- 2004 5.4 oil on number 6 plug
- Wheel Bearing Question
- How do i decode the Line items on my 2007 F15 FX4 build Sheet
- I tore my CV boot :(
- Catalytic converter
- 2006 F150 5.4 Triton 3V that started with the plugs...
- 2006 Lariat Tail Light No Power
- Aftermarket Hood Alignment
- A bunch of things wrong...
- HELP! Need to buy replacement key fob!
- AC whine
- Engine swap question....
- 2005 SCREW new Rancho QL struts .. still rake
- Confused and need help on choosing a used F150
- 05 XLT 5.4L triton performance mods suggestions?
- Tire question
- Engine studdering 2005 F150 5.4
- 05 FX4 5.4 inadequate fuel pressure. Help?
- FORD OEM 7L3Z-19A361-AA Vehicle Alarm System
- 2007 FX4 5.4 Starter Issues
- No Auto Headlights but Parking Lights! HELP
- 04 FX4 Yellow - Graphics?
- Fuel Pump Driver Module - Just Change It NOW
- Well crap (lots of pictures)
- Front Passenger Door on 2008 Supercrew
- Has anyone tried out one of these Portable Power Bank and Car Jump Starters
- F150 Newbie Aftermarket Wheel/Tire Fitment Question
- Need 2004-2008 Frame Pictures
- 2007 8 rib conversion
- Did a boneheaded thing... I was cleaning the steering column...
- stupid u joint
- Airaid 400-531 PowerAid Throttle Body Spacer / Is it any good
- new window regulator.
- 05 Expy front vents not working a/c stuck in defrost / vacuum line woes
- Roush Chin Spoiler
- Okay here is the deal
- Front CV boot / axle problem
- Water Pump Bearing noise
- Towing
- What are my odds of needing the plug removal tool if plugs have been done before?
- Drivers side pads sticking
- Okay went to parts store
- 04 stx airbag light came on
- 06 5.4 Low Oil Pressure
- 04 Flareside Tailgate Stop
- Wheel Fitment
- ABS Light
- '06 f150 5.4L - Crank/no start
- O2, Fuel trim and nearly useless motor
- Question about 2006 f150 5.4l
- Trans Cooler Hose Assembly 07 5.4 w/ Towing Package
- 2008 supercrew cigarette fuse
- Instrument Cluster
- Ecoboost Exhaust on 2004 5.4
- Help me choose a new grill
- Battery Light Comes on When Stopped / All Electrical Gone
- What alarm system should I get for my 07 f150
- Need help with wheel offset
- Replacing rack and pinion
- Clicking/grinding after doing wheel bearings.
- What Other Year Factory Wheels Fit 2007 F150
- clock display
- 09-14 or 97-03 grille guard fit the 04-08?
- Need pics of domelights
- Flowmaster Outlaw Cat-Back System for the 2004-2008 Ford F-150
- Rear shocks
- Help! Leaky window corner
- Telescoping mirrors for F150?
- 2006 limited slip
- Dash Airbag Light Wont Go Out
- Needing new complete struts or shocks only?
- 5.4 2v swap.
- 2005 f150 5.4 fx4 vacuum issue
- 06 5.4L wont start
- Desperate but NOT giving up!
- 2005 FX4 5.4L Blown Engine, What Now?
- 2007 F150 oil cooler part number
- What is your milage
- One leaf broken left side
- POLL: Which pushbutton start?
- Has anyone Plasti Dip a whole vehicle?!?
- Inner tie rod and pulling right
- Reverse lights installed, pics!
- It was destiny .... rust hole in muffler
- Recent pics of my 06 FX4
- Wiring Bed Lights Using Cargo Lamp
- 2004 F150 5.4 Slipping between 1200RPM and 2200RPm
- Constant 12V Fuse 2005 F150
- Is this normal?
- Complete led conversion
- Steering Wheel Control Switches - can they be taken apart?
- 04 f150 wheel bearings falling out
- rattling noise and a jerking feeling on 04 f150
- Driveshaft?
- 04-08 4.6 to 5.4 3v swap notes?
- Pinging or rattling?
- 04 f150 fx4 spark plug
- Hard start/run after sitting a week
- Dangling ground strap
- Urgently Need Help!!
- 08 5.4 vibration while heat is on
- FX4 wheel question?
- Unknown Hose-2008 5.4L
- New Rotors & Pads - Now ABS Light is On
- 05-07 injector upgrade; Bosch Ev14 (08+s)
- 2015-16 badges on 11th Gen
- Chrome wheel cover replacement
- Fender flares
- p0172 and p0175 extensive diagnostics done so far. Out of ideas
- Fox Box question
- Lost 4wd
- anyone with a 2004 blazing yellow f150 fx4
- 2015-16 f150 tailgate on 04-08 models
- Oil pressure loss
- Mean bed shake
- After market Ram Air Hood
- Corroded gas tank locking tabs
