Unknown Hose-2008 5.4L
I found this disconnected and covered in oil under the engine. There are two rubber ends with the white connection in between. It looks like it's been torn apart on one end. I tried reconnecting but I don't think the connections are supposed to separate. Probably need a new connection.
Any idea what it's for and would it being disconnected cause the engine to shudder and stall when idling?
Looks like a vacuum line, possibly IWE but can't tell 100%.
Does one end lead down to the wheel hub, and the other end lead to a solenoid on the passenger side firewall?
Also looks like all you need to fix that is a rubber inline fitting, they should be at Pep Boys with the vacuum line parts..........
