View Full Version : 2004 - 2008 F-150
- Console Gear Shift Assembly
- Ball joint measurement
- Crack In Dash
- 08 SuperCrew
- Lower Arm Bolts coming loose
- Power points not working
- Driving problem fixed
- Considering buying new engine and tranny. Thoughts?
- Tried to clear a code, now my truck idles low
- Floor Jack Question
- 06 FX4 Death Wobble
- thinking about getting a salt spreader
- 2004 5.4 Ford F150 Air Duct Bracket
- PCM issues
- Require circuit info for Connector C238
- Motorcraft max battery almost dead after 5 yrs
- 2004 F-150 2nd spark plug replacement
- 07 FX4 4x4 Steering issues Bad Hard Lines on Rack
- Bilstein Leveling struts on new coils = bouncey ride!
- Broken spark plug went from bad to worse
- PLEASE HELP! Alarm goes off when key is inserted
- Lost dipstick for transmission
- Can't find replacement 4L34-9C052-AA 2004 f150
- 04 4WD wheel bearing
- Problem with the new spark plugs? (2005 5.4 3v)
- Frustrated and Stumped
- Yes... I'm back... :-(
- Ash tray switch panel
- Help Identifying this
- No cruise 2005 f150
- Help me identify this please
- Crown Vic Fuel Pump Driver Module
- Radio Trim Bezel
- 2004 CrewCab 4x4 Wheels and tires
- MBRP Cat Back on Amazon!!!
- 06 4.6L STX Blown Sparkplug
- Problem with camshaft
- 2007 4.6L parts database discrepancies
- 20" - 18" Specs Help
- 5.4 Exhaust Manifold recommend/guidance/advice
- F150 lariat 2004 - wiring problems - please help!
- Painted Fender Flares
- 2008 - Replacement Tailgate w/camera - How to wire?
- Back-up Camera causing Fast Blink?
- 2007 6'5" bed extender
- Code Alarm remote start fobs won't lock doors
- 2007 F150 Numeric Keypad problem
- 2005 Cylinder MisFire Issue
- Been gone a long while. Status and plan.
- 5.4l 3v Not Your Typical Stalling Issue
- Spare tire cable setup?
- Groundhog wiring damage - I can't even believe I'm posting this
- 04-08 1.5" front level with 275/60(65)R20 photos
- Throttle position sensor
- Truck Running Bad - Need some insight
- 5.4L 3V engine woes. Rebuild or replace?
- passnger side exhaust manifold
- Raptor grill "F & R" for sale?
- Aftermarket muffler that isn't too obnoxious?
- PowerTrain help!!
- Intermediate Steering Shaft
- 2006 F-150 5.4L air conditioner problems
- Newer motorized steps on an '05???
- IWE Testing Questions
- code p0463, fuel gauge issue HELP!!
- Stock Fender Flare Body Push Pins?
- F150 No Electrical
- Seat conversion
- 2004 F-150 Airbag Code 34
- Alternator upgrade
- fuel pump lock ring
- 5.4L Misfire/Rough Idle/Low power
- A lot of work went into this build, but...
- F150 problems not starting
- Where can I find 2 spring seats?
- Knocking noise
- Help!! 04 f150 4.6l hesitation/falls flat!!
- 2006 FX4 Service Manual?
- About to Begin Front End Work...Need Tips, Tricks, Sanity
- Intermittent Brake Vibration
- Need help with misfire
- Vacuum weird
- 2005 F150 Lariat power mirrors
- Will grill mounted camera survive hood slamming?
- Timing chain kit
- Where to order OEM Parts
- 2005 Raptor Lift
- 2008 Ford F150-Replace dome light cover.
- Removing exterior plastics
- '06 F150 Radio won't turn off
- Fuel pressure drops to 0 after 10 min. on shut down
- Bad iwe?
- 07 Blower Fan - New Resistor and it's still stuck
- P104 code
- Seized 5.4 Triton How to Remove Engine
- Rear End Rough Ride
- Argh...this not other one- clunking when TURNING
- Rear Mat Showdown.. Which is the best.
- Changed Plugs....FML
- Roof Gutter Trim???
- Rear sliding window water leak, parts ?
- Top Stabilizer end link nut
- Seat cover recommendaions needed.
- 2005 F150 Fx4 hesitating
- 2008 Ford F-150 4.6 random missfire
- Truck rolled 200k!
- Loose Steering
- Aftermarket black bumper pics
- Door Ajar AND Interior Door Locks Don't Work
- Transmission issues - need a shop
- fuel pump
- 07 KR Need Comfortable Replacement Seats
- 07 F150 5.4 FX4 po430 and po305 codes
- Center Support Bearing Bracket Snapped On One Side - Consequences?
- Front Hidden Winch Mount
- Torque Converter Shudder and Trans over heating
- New Step Bars
- Slip Yolk Seal Part Number help
- Question on exhaust
- Radio not going off when door opens
- Cam position sensor
- Rack and pinion replacement
- 2005 Instrument cluster
- Truck idle surges and dies out.
- Relays?
- Swap a 2004 5.4 3v for a 2010 5.4
- 06 XLT 5.4L header/cat/cat-back question
- 33x12.5 tires on 18x9.5 wheels with +24mm offset
- Knocking/clicking sound at low rpm's
- Accessory/cab power will not go off - 2004 F-150 SuperCrew
- Phaser, Lifter I DONT KNOW,,,HELP!!!!
- Is it possible to swap a 2004 5.4 for a 99 5.4? Or is it more trouble tha it's worth
- Old truck. New project
- 2004 F150, overhead console lights switch crusty?
- strange problem
- Back up Camera
- Need advice - 4x4
- Who has put an engine in their truck?
- 2004 f150 5.4 obx catted long tubes
- New member with a new to me 2008 F150 Limited
- 4x4 doesn't engage, P0171 and P0174 when switch to 4LO... IWE Solenoid?
- 04-08 5.4 3v bogging/losing power/misfire/hesitation/rough idle
- Flowmaster's American Thunder Cat-Back for 04-08 Ford F-150's and Lincoln Mark LT's
- Should I fix the phaser tick??
- Transmission Double Shifting ???
- Code trouble
- Exhaust Manifolds
- 2004 F150 rear end ?'s
- Clunk when I turn
- OBD2 Logger/Live Viewer
- Noise when braking
- 2007 5.4 3V hesitation has me stumped
- 2004 F150 backfiring
- 2008 F150 Vibration Issue!
- Tachometer fluctuating
- 04 F150 4.6L P0171 Bank 1 Lean
- Axle not turning after wheel bearing hub replacement
- 2007 starter solenoid smoking
- 2008 FX4 - Engine spins but no start, sometimes
- Rough Idle/ Stalling
- Help !! Looking for good repair shop.
- 2005 5.4 f150 misfires
- Do we have engine block ground?
- What do you guys make of these Data Logs?
- Hood out of alignment
- New Trans Questions...please take a look...
- Starter Woes... Plz Help
- Hard to turn wheels on 3.73 LS
- 2004 F150 cranks but wont start
- 2005 5.4L Runs Smooth, But No Acceleration?
- What does this plug go to?
- Spark plug broken/seized in motor (HELP)
- 06 5.4 Cranks but wont start
- Spark plug change, so much dirt I can't get socket on plug nut. Advice?
- 2007 5.4 Triton 3 Valve Spark Plug Help
- grounding wire?
- Shock replacement for fabtech 6" lift
- 2004 F150 electrical or anti-theft issue?
- HELP: FX4 2004 four wheel drive not working???
- Transmission fluid exchange help
- coolant leak into exhaust after intake replacement 2007 f150 4.6
- Leveling kits
- How does this happen!!!!!!
- Front pinion seal
- Code p0340
- Front differential / axle vent location?
- rough idle
- 2016 rear Axle Direct Swap in 2006??
- "drain tube" (?) near passenger side front O2 sensor... what is it?
- Edge programmer 2007 f-150
- Help truck starts idles then dies
- New Struts/Shocks and leveling truck
- Anti-Theft Options for our trucks?
- 2008 F150 FX4 Leaf Spring Upgrade
- 2004 Parking Brake Cable
- Rear differential pinion seal - who's changed it out themselves?
- 4 Wheel Drive Question
- rear differential breather... "connector"? missing - need part number please
- 04 f150 5.4l 3v Misfiring
- 04 f150 lariat screw 5.4l 3v rough idling/knocking? Etc
- Painted and Smoked Headlights?
- 2006 FX4 front differential cover / seal leaking - looking for advice
- OBDII codes , misfire
- 2006 F-150 Rough Idle / black smoke
- Backspacing With aftermarket wheels
- Jump Seat for Console Trade
- Air filter choice question?
- 5.4L - replacing power steering pump/return line/pressure line - who's done this?
- Front End Noise???
- Changer alternator
- Howling noise when turning right...and
- Question about oil change (06' FX4 5.4L Tritan)
- Monroe quick strut to Bilstein 5100
- Just finished lift kit install...
- High idle on start up
- Changing #1 bank 1 O2 sensor need help!
- 4x4 won't engage
- Need Electrical Help!
- Everstart vs. Autocraft
- Help
- 4WD won't disengage at road speed
- 2007 5.4 Crank No Start
- New to Ford....
- can I replace the trans cooler lines myself?
- Which Magnaflow High Flow Cats?
- Which fuel sending unit do I need?
- 2007 F350 Owners Manual
- Error Codes 2005 4.6
- "Bang" In Reverse
- Electric fan retrofit
- 6 inch or 4 inch lift on 295/70r18??
- 2005 5.4 stalls at low rpm NO CODES
- Rust in 08 Screw cab corner
- Engine Hesitation
- Rear lights went out while driving
- Rear vibration from a stop or turning
- Newb buying 04 XL V6 250000 miles
- 07 4x4 low stuck question
- Kornnut's 06 Flareside Build
- 2004 (new Body) 4x4 Lights up, Does not engage front wheels
- Oil leak questions
- 2004 5.4 3V engine interchange
- Small whine
- 5.4 3v v8 what is this?
- Power Steering Pressure Sensor
- Recently bought 04 5.4
- Changing AC Compressor
- Any help is awesome.
- Help needed. Wont start
