Ball joint measurement
Old Jul 22, 2017 | 05:23 AM
vroom_vroom's Avatar
This got so much action in the suspension section I decided to repost it here.......
wanted to see if one of you guys had a upper control arm floating around you could pull a couple measurements from. i need the base of the ball
joint width (where the top of the ball joint boot sits)
and the width of the stud where the bottom of the boot sits.
i know the better option is just to replace the whole thing up this truck is operation low use
