PDA
View Full Version : 2004 - 2008 F-150
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219
  1. Saleen S331 Front Grille - Serious Buyer
  2. Considering this truck
  3. 06 4.2 Oil Leak
  4. Door Latch R&R
  5. Exhaust location
  6. Did an alternator diode test, what does my numbers mean?
  7. Using Oil
  8. Building some bumpers
  9. OEM Reverse Camera with Aftermarket Nav
  10. 07 A/C help
  11. Best Stock Air Intake Filter?
  12. Replacing the return hose easy way?
  13. My Blacked Out FX2 Build Thread
  14. 2008 F150 Gas Gauge Stuck on E
  15. "Factory" Remote Start Not Working
  16. 'Check Charging System' light on Batt/Alt Good
  17. 2006 starting issue
  18. Autolocks
  19. Preventative actions
  20. Check Fuel Cap Warning Help
  21. 325 60 18s
  22. Christmas Trucks
  23. 2008 f150 blower circuit problem
  24. yet another 3V plug issue
  25. Clanking noise under passenger side of truck plz help
  26. taking it to the stealership today
  27. Weird Electrical Problem??
  28. 04-08 winch mount
  29. Is the 04-08s that bad
  30. 2004 Lariat Air blowing on high with CC
  31. Violent Steering Wheel Vibration
  32. What To Look For When Buying Used F150?
  33. Need legal assistane!
  34. Transmission Oil Cooler Pressure
  35. Storing the truck for two months..
  36. Floor Shifter Knob Change - How-to. 2007 SCrew. [pics]
  37. New emblems on a 2004-2008?
  38. New grips
  39. 2005 w/ 142K trouble-free miles...what to do?
  40. Any disadvantage of installing LT headers?
  41. Thoughts on retread offroad tires?
  42. Anyone have the Frontier full bumper replacement?
  43. need opinions for next mods
  44. Question on Fuse Panel
  45. Problem with 4x4
  46. Battery Bracket
  47. 2005 4.6 S/Crew more idle problems.
  48. 2004 F150 5.4L SuperCrew running rough code P0171 Engine Light stays on
  49. Another check engine light on my truck PO303
  50. Jus passing on a petition to ford for the 3v
  51. Off-Road equipment comparison
  52. Custom Brush/Grille guard
  53. Not the first No Crank/No Start f150
  54. P1000 and P0171 codes
  55. Fog Light Goes Out
  56. CB antenna mounting? Bed mount
  57. Door Ajar/Dome Light/Outside Hi-Point Light
  58. Leveling Kit Install
  59. Keypad Help
  60. Heat issue
  61. $400 for Magnaflow cat back exhaust?
  62. Bad PCM or Reflash?
  63. Front end pop....GOING NUTS!!!
  64. Bizarre door lock issue...
  65. 2005 F-150 5.4L 4x4 shudder
  66. '05 rattle in 2wd, not in 4wd
  67. Fuel Injector suggestions
  68. GT500 Hood Vent Install
  69. Need Help with check engine light
  70. Noobie Looking for Advice/Mentorship...About to give Screw a facelift!
  71. Power driver's seat in an F-150 XL?
  72. Silverstars in reverse lamps with pic
  73. 3 Codes and ROUGH IDLE ***HELP***
  74. Transmission Drain Plug 4R75E
  75. 2006 Lariat 4x4 with floor shifter question
  76. Replace wiper motor OR multifunction switch???
  77. Water Leak - Need Help!!
  78. 05 FX4 Running Rough
  79. Winter Gas Blues
  80. Cabin air filter retrofit
  81. 4x4 Issue Please Help
  82. O2 sensor question
  83. Faking 4x4 :scared: and PTM 2012 badges
  84. Tow hooks on 2wd
  85. Heated mirrors on an XL
  86. Turn Signal, Brake Light, & Flashers Problem
  87. Truck won't start
  88. Help on Explorer whistle problem
  89. Want to level the truck, by dropping it....
  90. Talk me into keeping my 05
  91. Cam timing range at idle
  92. F-150 from Govdeals
  93. Something Rubbing in the front
  94. Old member, back on the forum
  95. N-Fab prerunner bumper
  96. Advice on issue...
  97. squealing noise from intake
  98. Those $60 nerf bars on eBay, question
  99. Missing in cold weather
  100. 2008 F150 FX4 ?'s
  101. Satellite radio upgrade
  102. Clicking relay in dash after LED swap
  103. Headlight Options
  104. Fall 2013
  105. Help! Starter Problems!
  106. Air plenum intake
  107. Once again another coil question
  108. Shift lever ???
  109. Engine mount nut
  110. Front End Time - UCAs, Ball Joints, Bushings - suggestions/tips??
  111. hood moving up/down on freeway
  112. Gearing up for the Cam Phaser job...what else to plan for?
  113. Opnion on my rake (pics)
  114. 07 Screw mini build
  115. Off center vibration/grinding in front end
  116. Suggestions
  117. PS o-rings - part no. or source?
  118. 2006 5.4L possible missfire?
  119. Airbox help!
  120. Multifunction switch buzzing
  121. Tires
  122. Noise in Tranny?
  123. Looking to upgrade my F150
  124. 07 f159 cowl panel
  125. DRL wiring connection
  126. Dilemma wiring lights.
  127. Radio door lock problem
  128. drivers side door lock not functioning
  129. Did my transmission filter and fluid exchange today on my 4R75E
  130. 06 Lariat SCREW Rattling at idle in gear
  131. No-More a Ford Owner
  132. 5.4 3V detonation?
  133. Symptoms of stuck fuel injector?
  134. No reverse
  135. New tires (pics)
  136. Bad Catalytics
  137. Dropped valve spring retaining clip
  138. Want to Buy: Driver Side Window Regulator 2005 Screw
  139. Official What Did You Do WITH Your Truck Today Thread.
  140. Painted Headlights Fail (pics)
  141. Programming Key Question
  142. Ford racing zero degree spark plugs
  143. P0171-p0174
  144. 2006 F150 V8 4.6 Liter - Looking at buying it used suggestions
  145. XL Rear Door Panel Removal
  146. Black plastic face plate question
  147. 2007 F150 FX4 Leveling Kit
  148. How to change the Serpentine Belt, Tensioner, and idler pullies on your 5.4 3v
  149. careful of oil changes 5.8 owners
  150. Brake Hardware
  151. Whining in 1st gear
  152. Need help, clicking noise!
  153. 05 Pin Stripe Removal
  154. 2004 FX4 front diff leak
  155. Steering wheel audio control
  156. 06 F-150 cutting out, hard to start
  157. Overhead rail DVD....what's it worth?
  158. Sound in dash...HELP!
  159. Tailgate handle plastic keeps breaking
  160. Completed phaser replacement, now no power and shuttering
  161. Looking for advise on cam timing. seems kinda odd
  162. problems any answers?
  163. Ranchos 9way adjusting
  164. High pitched squeal on acceleration 05 fx4
  165. Engine issues, need recommendations
  166. Parts name
  167. grinding noise possible iwe need help
  168. Just bought a 2004 lariat thats blown up!
  169. Troubleshoot Backup Cam Power
  170. Frame and Bed Assist
  171. Rear Parking Assist :: Recommendations
  172. "CHECK GAUGES" and no acceleration
  173. New exhaust, New head unit
  174. Transmission troubleshooting
  175. Another Possible Option for Upgrading my 2007 Screw
  176. A/C Fan Blower Resistor Location...Please help?
  177. Big Mod Weekend. Pic Heavy!!
  178. Plugs today, but broke the fuel gauge?
  179. disable tpms
  180. Heater Issues
  181. Sunroof Repair, One touch back isnt working right
  182. Lincoln Mark Lt
  183. Spark plugs change '07 4.6
  184. Double Din for my 2007
  185. What is This and where should it go (Pic)
  186. Options for New Shoes on 2007 F150 4x4
  187. Another Ignition Coil Question!!! LOL!
  188. Need new struts and shocks
  189. 2005 f-150 key issue
  190. Found a badge creator
  191. 5.4 Misfire! I need your help!
  192. Factory Remote Start Issue
  193. Looking for opinions.. Keep or Sell
  194. 2004 5.4L 3V. Which plugs and COPs?
  195. Command start. starts and stops.
  196. Heads up- front suspension
  197. Ordered new front seat covers from Headwaters tonight!
  198. Help rotor decisions??
  199. Thinking about selling , how much shoudl i ask for
  200. saleen1013's Retrofit
  201. exhaust manifold leak after plugs
  202. Dreaded Ticking
  203. Intermt shaking in steering wheel
  204. LED OEM Taillight Project.
  205. Need advice on upgrading my truck...
  206. Noise in doors and back glass
  207. Spark advance reading
  208. Best looking gauges
  209. Lights in the little grill???
  210. Rancho Quicklift woes (PICS)
  211. Friendly reminder-Winter's coming
  212. Spark plug change successful! But :3
  213. Rim & level check pls
  214. Hypertech max power programmer
  215. Replacing Belt Drive components
  216. New level and tires... Pics!
  217. 2005 F150 Exhaust Leak? VCT? All of the above and then some?
  218. Changed Plugs... now getting a P0112 Code
  219. 417,000 .......
  220. Better oil pressure reading
  221. Opinions
  222. Need help, bad. Truck died after oil change..
  223. Rough and dying at idle.
  224. Anzo signals on 05 OEM mirror
  225. Need lots of honest opinions
  226. Tow Mirror puddle lamp questions
  227. Have to pump the brakes
  228. Changed cluster/dash leds. Painted rims!
  229. loss of trans fluid? check your transfer cae.
  230. My Mod plan, any advice?
  231. Rear Wheel Well Liner
  232. '07 FX2 Radiator Question
  233. 4x4 decals
  234. 200K club
  235. Lightning Concept Tail Lights
  236. Sway bar links
  237. Centric Brakes
  238. Hey guys, about to do a tune up on your 04-07
  239. Best M/t?
  240. 05 Step bars/Running board price>
  241. 2010 F150 rear window fit a '06?
  242. I think I have a PATS problem
  243. How to remove head restraints - XL?
  244. A/C and u-joints??
  245. Will I have to trim feders?
  246. 2004 to 2006 phaser issue
  247. stock stereo questions...
  248. '08 Lariat without Heated Seats - pre wired?
  249. I think we need a new category! 200,000K!
  250. Misfire at completely random times, engine load, cylinder, etc
