Weird Electrical Problem??
Old Dec 23, 2013 | 01:39 AM
benny8777's Avatar
Hey guys,
So I'm having a bit of a weird electrical problem. Not sure if it makes a difference but this just happened after a long nasty blizzard. I was previously had a damaged cowl with about 1/3 of it missing. When I came out everything was iced up and full of snow including under the cowl. I have since replaced that.
But to get to the main problem my driver side door seems dead. Power windows/mirros don't work at all, door locks don't work from drivwr side but work fine from passenger side. The accessory delay stays on when I open my door as if it's not recognizing my door being opened but shuts off as normal when passenger door is opened.
I have been searching the forums and haven't really found the same problem. I have checked a number of fuses that were referred in similar issues but they are all good.
Is this a fuse, relay, or harness problem?
Can someone with electrical knowledge please help me figure out what the next step is?
Thanks to you all in advance.
Old Dec 23, 2013 | 01:44 AM
benny8777's Avatar
My apologies, I should probably mention that this is a 2005 F150 XLT Crewcab 4.6L.
