'07 FX2 Radiator Question
Old Oct 13, 2013 | 05:53 PM
flahiker's Avatar
I have an 07 FX2 that has a leaking radiator. I have flushed and drained the coolant. The upper and lower hoses along with the small fill tank hose have all been removed. The transmission lines however are a problem. There is a nut / fitting that appears to be swaged onto the transmission line. I removed the fitting from the old radiator but it will not fit into the new radiator.
I have done some reading and find references to a quick disconnect tool. I bought a kit from Advance Auto. I can't get the black slotted tool over the transmission line. Do I have the wrong tool? Any help will be appreciated.
Thanks!
Old Oct 13, 2013 | 06:22 PM
ckforker's Avatar
I was not able to find one that worked, so I modified one of the aluminum ones to fit. They are supposed to have one in the box if u buy from ford. Mine did not.
Old Oct 13, 2013 | 06:26 PM
429 boss mustang's Avatar
I used a saleen s331 radiator, its off their version of our trucks. It's a duel bypass. Ford racing makes one as well. Fittings worked perfectly. :3
Old Oct 13, 2013 | 06:27 PM
flahiker's Avatar
So those fittings do come off the lines! Does any one know what tool is required? How do you use it?
Old Oct 13, 2013 | 06:32 PM
Go to ford and buy one. Autodumb and O really? Carry cheaply made ones that are too thick.
