Troubleshoot Backup Cam Power
Old Oct 31, 2013 | 07:00 PM
HunterFL772's Avatar
Hello all,
I have done a lot of searching and reading but have not found a suitable answer for my situation. I have a tailgate handle camera purchased from tailgatecamera.com. It requires a power source at the rear of the truck, but I want it to be on all the time.
I have already stripped and put the voltmeter to the wires in the 7pin harness but none get power unless a trailer is plugged in. I have tried the orange acessory wire in the back of the harness and multiple ground points but to no avail.
I dont want to wire it into the reverse lights as I want to be able to view it all the time. So where do I pick up power? At this point I think I am going to have to run it back into the cab and find an ignition activated power source.
Old Oct 31, 2013 | 08:15 PM
MGDfan's Avatar
Hi.
This help any?
https://www.f150online.com/forums/el...era-power.html
Cheers
Old Oct 31, 2013 | 08:55 PM
Thanks, that was one of the threads I have read up on.
The problem is not that I can't find the wire, it is that the wire is not hot when the truck is on.
Old Oct 31, 2013 | 09:14 PM
Ok, I have narrowed it down. I have not installed the harness for the brake controller and included in that process is the addition of a relay in the fuse box. There is an empty slot for the relay.
Any ideas where I can get that relay? Or have a part number?
Old Oct 31, 2013 | 09:34 PM
MGDfan's Avatar
Hi.
See: https://www.f150online.com/forums/to...locations.html
Posts #20 and #43. Looks like Autozone has them ( it is just a full ISO relay ). Dealer will also have them but at higher cost most likely.
Old Oct 31, 2013 | 09:39 PM
Watson91's Avatar
Check that 7 pin again. They should be getting power regardless of a trailer connection? I wired my aux reverse lights into the back of the 7 pin.
Old Oct 31, 2013 | 09:47 PM
Yep, I am just missing one full iso sized relay.
Here is the answer I have found: skip to 2:45ish in the video
http://www.etrailer.com/tv-install-t...50-118247.aspx
Old Oct 31, 2013 | 10:15 PM
Watson91's Avatar
Does your truck have factory wiring to the hitch? I don't understand why you would be missing that relay if so. Just curious?
Old Oct 31, 2013 | 10:19 PM
MGDfan's Avatar
Hi.
That relay ships in a baggie (along with a brake controller harness) in the glove box in a new truck - its not installed by default. If the previous owner never installed /tossed / lost it...
Old Oct 31, 2013 | 10:24 PM
Watson91's Avatar
Originally Posted by MGDfan
Hi.
Good to know. I bought my truck used with 10,000 on the odo. but I guess the previous owner had already put the relay in.
Old Oct 31, 2013 | 11:32 PM
I have the harness and relay back home. Not currently near home so Ill just go to advanced and pick up a generic one
Old Nov 1, 2013 | 10:38 AM
SoonerTruck's Avatar
Yeah, the 7-pin doesn't work unless you insert the relay that came with the trailer brake harness. I really wonder why Ford did that, simply because it seems like it would have been just as easy to put the relay in from the factory. Using a 7-pin connector doesn't necessarily mean that the trailer you are towing has electric trailer brakes.
Old Nov 2, 2013 | 12:43 PM
Back up cam now working! Went and got a full iso relay at autozone and the 7pin is now powered. I guess they keep prices down by not putting in that relay...
