View Full Version : 2004 - 2008 F-150
- New bumpers wanted
- Brake squealing when not braking?
- Flareside Line-X PICS
- Kit supercharger Whipple Model: M-6066-F105
- My Before and After Wheels and Level Kit
- Spark Plug Mayhem 5.4 06 f150
- What does it take for a 2004 F-150 5.4L 4X4 to make it to 200k miles?
- I Scored Some New Wheels For Free!
- Problems and need some help please.
- To change or not?
- OD Shudder/Misfire/Stumble
- How is your Showroom New Trim dye or Krylon Fusion holding up?
- Truck Transport?
- Center console shifter replaced
- gps vs odometer??
- HELP: Space between front bumper and upper cover
- who wants cheap Amp Research PowerSteps?
- Successful spark plug and COP change...so far.
- Well. Things don't look good for my motor.
- headlghts??
- XL-3 and 75W-140 worked like a charm!!
- 2011 towing mirror on a 2006?
- super excited
- Power mirror jumps and click
- broken plug removal
- 2005 injector issue
- grille? and bumpers?
- why cant we get this hood?
- bye bye 08'
- 04 5.4 3v Plug replacement
- When towing in O/D, tranny noise/vibration when downshifts?
- '07 Lariat Oxygen sensor replacement
- New Guy
- Factory nurf boards
- will 09 tailgate emblems fit our fenders?
- screw rear window regulator part # question.
- sprucing up the interior of my xlt
- Permanantly turn off OD???
- Need a quality body shop referral in HOuston, TX
- Cam Phasers or Catalytic converter? Rought Idle / Low power
- 2007 f150 A/C clutch problem
- 06 f150 5.4 has oil pressure problems
- *picture request* white/gold lariat no pinstripe
- New Wheels
- awesome stuff next 3 months
- Code P2196 will not go away
- Added Roush Side Exhaust and New Lights **With Pics**
- 2008 Ford F150 FX2
- STX 4x4 system, IWE's?
- Headliner questions..
- Flareside LED Tails
- SeaFoam
- Rubber cowling trim below windshield- 2006
- extended warranty
- Precautions about switching to synthetic
- Bullydog Watchdog mount+Roush Vent
- Green intake
- Gas selection
- 285/70/17
- Front driver's side wheel area ratcheting sound...
- 2WD Brake Rotors
- Camshaft sensor replaced - still the same code error
- Gonna bite the spark plug bullet soon
- Great News! Found Extended Service Plan!
- Front End Ticking
- Electric fans A/C wiring
- Rear Diff Fluid Change
- Looking for Custom 2004 F150 Front Bumper with Hood Guard and Rear Bumper
- Spark Plug Problem
- 2006 f150 starter issues....
- 2004 Ford F150 - Some advice?
- Gear Shift Engagement
- I luv my Chevy!
- Rear Window Leak
- Front and Rear End Issues
- random rough idle, no CEL, no explination?
- Slow but sure the mods are happening
- Noise from frontend
- What programmer do you have?
- Time for a change (new wheels and tires) <pics>
- New BJ's and Ranchos = New Truck!!!
- Kleenex!!!!
- Check Gauges and Beep?
- 80,000 miles what needs to be done?
- Power steering leak
- Need Tire Size For New Rims
- 295/70/18 Nitto Trail Grapplers
- DTC Code P0620??? Please Help!!!!
- Up hill squeel
- Changing the look of my '05 Lariat
- A Thank You
- Help! Ball joints or cv joint?
- Steering Wheel Shaking over 50 mph
- possible U joint failure? pics inside..
- Air bag recall...suspended? Check this...
- NEW 2011 Truck Flap Designs!
- Auto Climate Control has mind of its own
- Need help diagnosing noise
- What would you do?
- Wheel Bearings are they shot?
- Intermittant Driveline Vibration
- Quality 3rd Brake Light??
- Lowering a 4x4
- Replacing IWE's and CV Axles at 73k, what else?
- Ran Outta Gas - Now Having Problems
- 2004 With 119,000 Plug Change
- Another red FX4 decal on red truck change.
- L/F brake locking up and smoking.
- 07 Lariat Grille question
- My keyless entry is not operating properly
- I couldn't go 3 months without an F150...new truck *PICS*
- Bambi has suicidal tendancies...
- New (used) truck, did a bunch of maintenance
- Motorcraft Platnum - 4.6L Spark plug change, 2005 F150
- Rbp grill vendor
- Extended Warrante Question
- Promising gas saving device?
- Spark Plug change guide ?
- Updated Picture
- 05 screw with 148k...need brakes...would you change the caliper too?
- Few questions about lift
- 2005 F150 EATC Issue
- cruise control kaput
- new f150 owner and i need opinions
- My 05 FX4 Screw Build (Pics as updated)
- My Bass and Amp back seat Done !!!!
- Clunk...
- J.Walton's build thread (pic heavy)
- Shaking and vibrating truck
- project fog lights :)
- Finally, I have completed a few mods
- 11/29/04 production changes
- sluggish 2004 5.4l
- Help wanted on audiosystem and steering wheel control
- Heavy amount of grease, don't know where it came from
- What tire setup are you running on your 04-08 F150 - Post Pictures
- Need new engine after oil change
- Where to buy replacement CV Axle
- Hidden Antenna
- Excessive brake pedal travel after disassembly
- Truck Sputtering
- Leary on running 33s again, questions
- Grille...with or without?
- What to expect over 100K ?!
- JOY! I'm one of y'all now! got my Truck
- Engine is gunked up
- Boredom + spray paint = painted badges
- 2004 4x2 with leveling kit tire?
- intermittent miss, and code
- new 08' 4x4 5.4l XLT
- Problem :(
- Keyless entry numbers fading
- Need to add reverse lights to 7 pin connector
- has anyone updated to 09+ mirrors?
- Brake rotor help
- My Spark Plug saga
- Have a question about Header on my 06
- Massive missing problem
- My 04 needed a new PCM...ouch!
- Does the XL have in-door wiring for power locks?
- Greasing and lubing?
- Dual core radiator, why is it rusty, it just came in the mail...?
- 2007 F-150 Cigarette Lighter removal
- anti-lock trouble light in dash
- Beach Weekend
- Recon projector headlights
- Another new guy - FX4 screw
- SoCal Oldschool Alignment
- Burning Mirror
- Hitch help please
- Have to push the throttle 1/2 pedal before truck moves in 4wd
- Couple questions regarding rear differential and exhaust
- 2005 fx4 supercrew trans D.O.A.
- Horrible grinding noise when starting the truck?
- Lugnuts Keep Comming Loose??
- Post your pics of Bug Shields
- How hard would it be to build something similar to this?
- Interesting Starting Issue
- WWYD...tonneau cover rubed paint off (pics)...repaint or lineX?
- Just a little more height.
- Flooded Engine perhaps, need advice
- New F150 owner
- Need help identifying hose
- Looking at leveling kits...
- Park Assist Problem - 06 FX4
- help with hwy speed missfire
- 2011 Lariat
- ~ Window Squeeeaak!
- Body lift flareside
- Rear Sway bar question
- Bad Fuel
- Billet Pedals
- Very Dissapointed.....
- IWE Selonoid or other cause ?
- 2wd towing - LS, gears, and possible tire upgrades
- How to replace Lower Steering Shaft (04-08)
- Camshaft DTC after rebuild
- Very Please with the 5.4L MPG today
- 08 Engine/Transmission issue?
- Looking to purchase 2005 F-150 FX4, Few Questions
- 5.4l engine knock?
- Got room for 1 more here?
- wheel and tire ?
- best price on ford mudflaps?
- Is this possible? Keyless..
- Bg 44k
- Can Someone Please Help Me Find Headlights (search function used)
- Tasca in RI advice. Very good place for parts.
- 2004 5.4 Spark Plug Change. $680. Ripoff?
- Electric peddles
- As of Today, What Plugs do I get ??
- New To The Site
- 06 Scab XLT 4x4 Before/After Level & Tires
- Covering my PIE hole (cig lighter) - what did u do?
- Question about 2wd ride hight and a couple pics
- Bumper swap and Bull bar question
- Pics of Painted Mirrors Please
- Low Miles, How often to change the oil?
- Trying to blackout my 04 screw F150
- Issues w/ 06 part throttle/WOT
- Hints for selling?
- 4wheel drive question/problem
- HVAC controls messed up?
- Blend door actuator how to
- Stuck spare tire lock
- MAF sensor cleaning - did I get it right?
- Sticky brake pedal, no help with search.
- Long tube or short tude headers for 2005 F150?
- 04 F150 failed Emissions
- Damn leaky third brake light...
- Got the exaust finished
- NO FPDM on my 2004 F150!!!
- Front end NOISE!!!
- Engine Failsafe Mode after DWV Intake Mod
- come on ups man !
- 2006 F150 5.4 flex Swapped in a 09 5.4 engine running rough? Any ideas?
- Stop Tech Big Brake Kit
- FX4 suspicion
- Heated Mirror Problem
- Better brakes, other than just pads and OEM rotors or slot/drilled
- Whats next?
- 3" body lift
- Brake job
- leveling Kit
- Disengaging 4x4
- What is this???
- P0353 problem
- Lower the Rear or Raise the Front?
- 3 years old, holding up well!
- My Nathan K5 Train Horn Install
