View Full Version : 2004 - 2008 F-150
- 2004 F150 5.4 P0202,3,5,8 Inj Circuit/open
- camburg uca
- weird rattle and thump
- Few new pics from today.. New Exhaust
- My latest mod.....
- FX4 Decals
- horn replacement
- Power Seat Blowing Fuse (Resolved)
- 2005 F150XLT- Truck stalling
- Fpdm-----omg
- license plate lamp cover replacement
- new stock rims older truck
- Jeremy's Build Thread
- The Official 04-08 Leveled Truck Thread
- Tonka Truck
- dash power point replacement
- 5.4 330ci 3v Engine Kits
- 2004 F150 Rear Gas Tank Strap Removal
- Tint (Ca)
- For what is this cable?
- 2004 Screw FX4 Bad 9 MPG??!!
- 2007 trans vibration
- spark plugs
- Body shudder over bumps
- Edge p2106
- Newbie in need of help with towing and payload question 2006 f 150
- Smittybilt Predator installed w/pics
- Controller mount
- highest mileage on original plugs
- Shifts without break on and no cruise control
- 5.4 mileage. Again
- 5.4 mileage
- 06 5.4L - truck stutters, shuts off.
- Odd non engine or driveline noise. any ideas welcome
- 2005 FX4 Scab fuel capacity??
- Help finding a thread. HOWTO on replacing ball joints.
- This should look good on my truck!
- Fluid Leak
- morning disaster
- Front end rebuild. Waiting on parts is killing me!
- No rear defrost
- More lift from fab tech
- Passenger Side Front Quarter Panel
- remote start issues
- Battery Drain
- And The Estimate is in.....
- leveling kit help
- Climate control blinking and blower relay making loud noise
- 2004 F150 winch mount that I made
- Creaking from front-end
- Tire size dilema
- Aftermarked Nav Headunit Conversation
- OEM Fender Flares should I paint them or leave them black?
- 04 f150 engine failsafe.!! Please help
- Stupid Window Regulators!!!
- AUX switch idea I had. opinions?
- Scanner recommendations
- Where's Waldo
- Some fall pics!!
- Which digit in serial number denotes wheelbase?
- troyer efan simple wiring ?
- F150 2007 fx4
- HELP!!!! PLEASE!!! ABS Problem
- Black friday sale going on now @ ajusa
- iwe solenoid cover
- Great thanksgiving so far I think my fuel pump took a poop
- Block heater
- More Pictures of New Truck! 04 FX4
- Electric Door Locks / Radio / Auto Headlamps
- Roush Nightmare Seat covers
- topper
- Rattle under floor when stopped - A/C or 4x4 related?
- Idling issue help!!!!
- 2005 5.4 not running right Help!
- 2007 f150 fx2 5.4 v8 flex
- IWE on the way out?
- Misfire Problem Fixed
- Remote start question
- Head light and Tail light Conversion to 09+ and Raptor Grill??
- calling all 5.4 mechanics!
- Quick pic of new look.
- Help 5.4l
- 2005 f150 5.4 2wd wheel bearing drama!!!
- Auto-dim rear view mirror
- Loose passenger mirror
- 3" level kit
- A graoning sound????
- Moog UCAs and lower ball joints anyone?
- Transmission ???
- Removed fuel tank, dumped bad gas, and now my truck won't start
- warranty nightmare
- 60 mph shudder
- A Couple Pics From Today
- Tilted Ride Height
- So do I have the cam phaser issue or not?
- bfg ko at 275/70/18 fit 10 in wide rim
- Loose antenna
- HeadRest Monitors
- Transmission Treatment
- Anybody Got Rain-X Wipers
- Screw roof knocking
- Keyless entry code
- squeaking driver door
- Want to swap gauge cluster
- Want to swap my 4.6 with a new 5.0 coyote is it possible
- 5.4 3v injector tick/knock noise
- New Truck: 2004 F150 FX4
- A Few Shots of My 05
- Finally back from the body shop!
- S331 hood on but
- 2008 F150 crew 5.4L 4x4 light flash 1 time and no engagment
- 2012 Steering Wheel
- 04 F150 5.4 3v Oil Pressure/ Cam Phaser (sorry)
- Deer strike: Before and After
- Thinking about going with the Quicklift.
- power rear window
- Firestone Ride-Rites Installed (Pics)
- Transfering transponder chip into new key that is a shell only?
- "Mile"stone
- Shop tells me ball joints are bad... I need a good jack.
- 04 FX4 Vibration
- kc lites
- Prevent cam phaser issues?
- Dash Ghost
- 2004 supercrew 5.4
- Pic Request: Where Does the In-Vehicle Temp Sensor Flexi Tube Attach
- I want to do something with my side badges...Opinions?
- So I have an SCT Xcal3 tuner laying around....
- on "on" and "set" buttons work on cruise control.
- Second spark plug change questions
- Bumper Finishes - Which Would You Go With?
- 4wd steering issue
- Cam Phasers going bad how long before new ?
- Cruise Control Issues.
- 05 f-150 5.4 super cab 4x4 no egr hose on exh manifold ??
- 08 problem filling with gas
- 09+ jumpseat swap
- Westin HDX Grille Guard
- *&#%! transmission cooler line!
- Replace springs in 05 F150
- Cowl End Replacements for $20
- temp gauge pegged!!
- should i buy or not? used truck
- Where is the Best Place to Tap into Reverse Wire for Back up Cam?
- Frontier Brush Guard Installed
- Need Help with EATC Swap... A/C Demand Wire
- New F-150 Owner!
- Level and tires...again
- 09+ Badge Upgrades?
- Need some guidance on Axle shims
- New Tires WHOOP!!
- 2005 f150 xlt rear end rebuld
- pre runner suspension system
- Thanks to all
- Good News and Bad News...
- Airaid Jr CAI
- Leveling Kit this WEEKEND!
- Extang trifecta
- This may have been covered...But i didn't see it.
- need help with heated mirrors
- front brake set up :(
- Bad Clunk in overdrive
- Good EMTC to EATC Swap Write up?
- 09+ Front End Conversion Crewcab
- Matted my 05
- Oil drain plug replacement
- to level my truck or not to level my truck that is the ?
- 4x4 wont engage/do anything
- Pics Of My 06
- 2004 F-150 Replacing Timing Chains and Guides
- Pic in Garage-- Check it out
- Passenger Window switch
- Gloss Black Pillars Done
- 4x4 low working but 4high not?
- 09+ Door Panels
- Should I put my converters back on?
- Ac clutch wire found for electric fan install
- Winch mount bumper, and OEM fog light issue.
- Transmission oil cooler recommendation needed.
- Will it fit?????
- Question about Top Speed - Kinda Long
- 06-08 fog light install help
- Overhead rail system storage
- black or gray bumpers
- Block or Shackle for back
- Who is the best tire wholesaler?
- Black lariat with lariat chrome package.
- Steering Issue, almost lost control!
- GOPRO 3's
- 2005 king ranch
- I need my big trailer plug-in working.
- hvac control
- Shock/coilover replacement opinions needed
- Keyless Remote issues
- 2006 stx helpppp radiator support
- Hi Lift Mounting Options
- Radio Swap???
- No more truck..Got me an EcoBoost
- Pinion flange torque? 9.75
- Tire size
- Bad cat?
- Advice for my First 05 F-150 KR?
- Slow Passenger Window
- Clicking noise at wot (video)
- PTM Mirror Caps
- Is that F-150 a Diesel??
- Front Rotors replacement
- Aux Placement
- Has this been done?
- Dent removal Input.
- Console and dash wire locations?
- No stereo or 4x4
- Engine Running Rough and Dying out at Stop
- successful plug change
- Got a stubby!
- Spare Tire lock cylinder
- Tool Box Bed Cover
- 2005 fx4 door locks
- hi guy new here
- Wiper Cowl restoring
- my new used f150
- No Longer In The F150 Family :(
- A/C Blowing Hott Air
- Help with my new truck
- I have the Banks Air intake and Edge Evo, should I ditch the intake?
- Anyone running 275/70/18's
- chip and intake
- overdrive?
- Heated seat module question
- proud to be part of this forums and.........
- 2005 Ford F150 Rattle Under Dash
- Plug change, used 1600F anti-seize, what to expect?
- Spark Plug Change tip of the week
- keypad
- removing rear drums 1998
- Font Shafts or IWE?
- Weird Noises inside Center Console
- spark plug/cop question
- Heres my Fx4's progress
- My new to me 2005 F-150 Screw 4x4!
- Check your Butyl-Pad recall spot!
- Climate Control Issues
- maybe rear main --not sure
- heated seat module question
- Orange Wrench Light
- Mirrors
- Trying to Install Leather Seats Need Wiring Help!
- just joined today--2005 fx4
- 06 f150 4.2 oil on plug threads
