Leveling Kit this WEEKEND!
Old Oct 26, 2012 | 09:27 AM
Kbrindle's Avatar
Putting on the 2.5" leveling kit and possible 1.5" block for the rear this weekend. Wish me luck.. Any tips before I get started
It's an 05" fx4
Old Oct 26, 2012 | 07:19 PM
thisguyuknow's Avatar
Just did a 2 inch level last weekend. I had a harder time with getting the driver's side coil over back in because the lower control arm didn't drop down far enough. I had to use a coil compression tool from the local parts to compress the spring and line up the lower shock mount. It was a pain but the pass side went easy with no back talk. Overall took about 1.5 hours and I did it while at work on out lift so technically my work was paying me to do it.
Old Oct 27, 2012 | 09:14 PM
dbhost's Avatar
Once you get it in, and everything tightened / torqued back to specs, GO OVER YOUR BOLTS AGAIN, and recheck the torque... After you have triple checked to make sure it's all back together right, and torqued down correctly, take it on a short road test, not far just a couple of miles and back, then recheck the bolts one last time. THEN take it to get an alignment...
Old Oct 28, 2012 | 12:02 PM
projetmech's Avatar
My kid did his 08 yesterday. Drove pretty bad on the way to the alignment shop.
Old Oct 28, 2012 | 12:59 PM
97isnotold's Avatar
any reason for the block? my fx4 sits level with a 2.5" level and stock block
Old Oct 28, 2012 | 05:46 PM
projetmech's Avatar
On my kids truck the bed rails are level but when measured off the tire top to the wheel well lip the front is one inch more than the back.
Don't forget to adjust your headlights. The low beam was the height of where the hi beam should have been.
Old Oct 28, 2012 | 07:35 PM
The OP probably wants to keep some rake in the suspension. I coupled my 2 inch level with 3 inch blocks to keep the rake.
Old Oct 31, 2012 | 02:41 PM
hearnoevil's Avatar
I put in 2.5 and needed the block. it was too high in the front with out the block
