View Full Version : 2004 - 2008 F-150
- New guy, new (used) truck!
- Rough Idle - 2007 4.2 XLT
- 17" to 18" rim now low pressure sensor wont deactivate
- '05 5.4 acceleration issues?
- 2004 Remote Start Questions
- Those with aftermarket alarm/remote start ?
- Rough idle
- Remote Start install help - 2006 F150
- Would floor mats from a 2015 fit my 07?
- VSM Module
- In need of some advice! 08 fx2 sport tires
- Spark plug class action lawsuit
- Vibration while stopped
- Cam Phaser replacement
- Parking Light Wire
- New grille emblem
- front end alignment, steering wheel crooked?
- Please help
- Parts Arriving Finally
- Pics: 33's and 1" level
- Turn Signal Issues
- Need Quality inexpensive Headlight Replacement
- 06 wiring issues
- Unknown plug in dash (pictures)
- Noisey Rear.......What a PITA. Rebuild Pics
- Will remote start work with factory keypad?
- Lift Measurement Help 37s
- P0022 Engine Code
- ANy 2007-2008 guys replace your 4x4 (IWE) solenoid?
- 2007 Ford f-150 clicking & scraping in front end
- 05 F150 caliper question.
- 2006 F150 XLT HEATER CORE HELP! 145k mi
- remote start addon activation input
- installed 5100 shocks, only 0.5" lift?!
- 07 4x4 Steering Overhaul Questions
- HELP! Grinding noise while in 4x4
- What is symptom of failed IWE check valve?
- Leaking power slide rear window
- Delta Pressure for Upstream Hose Test and Threshold
- Exhaust manifold video
- 2004 f150 complete transmission rebuild
- my 04 has really bad frame rusting and holes?
- Adding some antifreeze to IWE actuator
- Rebuilding Front End
- p0420 code help
- Any writeups on Replacing calipers
- 2007 tailgate won't come off
- 05 Stall/Died/No Start Has Me Stumped
- Two OE tire sizes to choose from, a bit confused.
- Different size auto spring ?? Old vs new
- 2006 f150 power issue with AC clutch
- Which VCT Solenoid from Rock Auto
- Gearing advice needed
- FX4 Overdrive Light in Instrument Cluster
- I want my headlights to turn off when the key is in the "off" position.
- Possible Ac fan issue
- Helping my son upgrade his 2006 FX4 tires
- p0171 p0174 codes
- Old Truck Dead... New Truck Project! ('08 F150 Lariat)
- Difference between 04-08 and 09-10 suspension
- Finally leveled
- Factory power rear sliding window
- Now The Ball Joints
- Lean Bank 1 only (P0171)
- Leveled + body lift = 37s?
- pics of new 295/60r20 open country mt's, cv axle recomendations ford or aftermarket?
- Oil Sludge ruined??
- 2004 f150 engine failsafe mode
- 2006 F150 4.2 high temp issue
- P0012, Different than most???
- Noise
- F-150 2005 5,4 triton IMRC IMRCV ? Diagnozis
- random no-start has me stumped
- Put a winch on finally
- 2008 f-150 4x4
- 07 f-150 running rough
- If the 7l3z-14b166-BA Transfer Case Switch
- back window upgrade
- 2005 fx4 4wd ???
- Tow Mirrors
- Ac issues, advice needed
- Gas Gage reads empty
- Is it even possible?!
- Noisy 08 F150 5.4 L
- Which truck to buy?
- Need opinions on regearing
- 2006 f150....
- Need an opinion on my existing tow package
- Fuel Mileage 07 KR
- CMCV deleted?
- New Roush Supercharger Installed - HELP!?
- What to do now...
- Original spark plugs?
- Sticky sunroof leak?
- Coolant leak
- Banging sound when accelerating on an incline.
- 04-08 Service Manual PDF out there?
- help me out- intake filter rot- need replace
- 2007 F150 Door key pad not working
- A/C stuck on defrost. I found broken hose but need help finding source
- Door ajar light and Drivers side door lock
- Imco muffler
- Looking for fender flares.,,,05 f150 XLT
- Truck has a bad squalling
- Bad Break Hose?
- Wheel spacers on 2005 f150?!
- 2005 w/ 5.4L V8 Triton issues (P0174 & P0303)
- Bent Exhaust Valve-valve stem hole broken
- Shined her up yesterday ....
- 07 F150 Lariat AC not working
- Leveled truck with 35's on 18" rims
- Just bought 07 F150 with 4x4 problem
- Fog Light Flash Disable when Locking
- Random Misfire in all cylinders!!!
- radiator trans line fittings
- 08 oem dvd?
- Project No Truck Payment
- Truck Died While Driving, Now It Won't Start, PCM Issue???
- Amazon Auto Parts?
- Does anyone make a wood kit that actually matches the factory stuff?
- Introduction
- Several problems with 06 5.4 3v
- What mount for roof light bar?
- cam lobe pics... normal?
- 2004 f150 5.4l 4x4 driving me nuts
- No Fuel Pressur at Start, Low Pressure under load
- Radio/Temp Bezel Rear Clip
- 2005 F150 shudder
- Unplugging alternator harness?
- Goodyear Duratrac or General Grabber AT2
- My truck files from Troyer Performance?
- F-150 with Leer top cover
- 06 F150 5.4 No crank/no start
- Opinions on my fix
- 2004 5.4 Air/Fuel mixture off???
- How Do I Fix It?
- P0191 Need to test Fuel pump
- P0446 Error
- Thinking about lowering my 4x4 more. .. currently 3/5. Have few ?s
- 2007 F150 Door Ajar Light and Driver Power Door Lock.
- Biggest tires on 07 KR with 20's?
- 2005 5.4 "bucking" but only at certain RPM?
- Swap Grand Marquis 4.6L in F150
- P.a.t.s. Problems - please help
- Help in trying to decide
- 04 f150 wont engage when put in drive!! have to shift to 2nd please help!!
- Need help!!
- P0054 and P2270 OBD codes
- 2005 F150 Emergency Flasher Issue
- Moved on from F-150
- What brand of IWE's have you guys used?
- no fuel pressure
- Anybody Ever Replace their Rack and Pinion?
- Is my truck losing power, transmission going, or am I going crazy?
- 2006 Harley missing and bogging on hard acceleration
- Fuel Tank skid plate compatibility with 09-14?
- 07 4x4 steering rack issues
- Limited floor mats
- Do you drive by the compact spaces?
- A/C system replacement
- 2004 f-150 Rebuilt Engine Serial
- Leveling my truck, rims and tires question. Please help!
- Any Suggestions !! Trying to figure out size of the motor
- AutoAnything Giveaway – Michelin EdgeLiner Floor Liners!
- tire sizes
- 08 5.4 3V Sucking type noise?
- New member... Need help!!
- Rims with tires FS (BF Goodrich T/A KO) - in classifieds
- Help Diagnosing a Mild Misfire at Low Idle - 2007 F150 4.6L
- Front bull bar recommend ?
- Power Steering Cooler, tube only or w/fins
- 04 FX4 Issues
- radio swap
- no mechanical air moving in 06 F150 stx
- Best source for updating all wear parts of the front suspension?
- I assume the answer is NO, but......
- Radio not working right.
- 05 5.4 cam phasers not locking at idle @ operating tem
- 07 5.4 Screw hesitating
- Aftermarket tachometer wiring
- Lariat to FX4 Speedometer cluster Swap
- High Mount (3rd) Brake Light
- Here it is! New JDM Fuel System
- Goodbye and Thank You!
- Is my truck Flex Fuel capable?
- What is this part? HELP!!
- f150 tire size and front end issues
- Any advice is appreciated
- Need Part Number
- HELP I need a pulley and Troyer disappeared.
- Looking for My new used F-150.
- Dreaded CHT sensor replacement
- blower motor
- Scratching, squealing or something
- Any install tips on Rancho Quick lifts???
- New Member/Project Thread (04 FX4)
- manifold craked. Pacesetters OK?
- Can I go bigger radiator??
- Tires: 295/70-18 Terra G2s or 285/65-18 KO2s
- Weird MPG
- Adjusting Rancho shocks
- Sweet Winch Deal at Harbor Freight
- Bi-Xenon headlights from Black Flame Customs FS in the classifieds...
- A big thank you!!
- Towing 7000# with a 2004 4.6
- ABS light came on
- Rear power sliding window motor
- jasper or monster which is the better transmission?
- 2008 f150 leveled??
- Bought my first truck: 2004 FX4 SuperCab!
- Same Plug: Fuel Pump/Fuel Level Gauge?
- 2005 f150 5.4 overheating
- 2006 f150
- Added 3" ReadyLift Rear Blocks
- Can't find where the License plate wire goes on my 2005 fx4
- Rail mount DVD unit
- In the market for a 04-08 .. Need advice
- 2005 fog light replacement
- New Long Block
- Little Jealous
- S&B CAI install on 2007 F150
- 4.56 gears with 31.5" Tires????
- Odd noise
- Cam phasers? Timing tensioner bad?
- Fuel Filter Shenanigans
- My '07 Redfire XLT
- Rear bed steps??
- Fuel Gauge Fuse?
- Hey folks
- Sunroof repair write-up or video?
- O2 Sensor - P0430
- Dealer Coolant Flush, $189 OK?
- LED light bar in bumper pics..
- 285/65/20 and 2" level?
- Cause of intermitent engine or driveline vibration???
- Famous 5.4 tick!
- Shakes while braking
- Strange Vibration
- Plastidipped the whole front of my truck today (PTM)
- Finally, that job is done .... Tires.
- lights not coming on in auto mode
- 2008 fordf150 stalling issues
- Horrible Noise
- New Fob
- 05 xlt 4th gear TCL
- 2012 Raptor Console in a 2005 XLT
- only starts hold key on for 2 seconds than cranks
- Water sitting under floor trim
- I found that annoying "thump" on takeoff, now where to get leaf spring bushings?
