Cam Phaser replacement
Hello all! Let me start by saying I don't know a thing about trucks... But you all seem to know quite a bit, so I am here to ask about an issue my truck is having. When I drive it for a period of time it starts to sound like a deisel when I idle or start to slow down. After some research I figured it was the cam phasers, which was confirmed by the mechanic I took it to. They suggest a new engine. They said I should take it to a dealership to do the cam phaser replacement as that would be cheaper than if they did it. I don't know about any of that, but I was hoping someone here might have better insight. I'm also curious to know what the consequences are if I don't do anything. Will my truck explode or will I just be an annoyance at the drive thru? Thanks for any insight into my issue!
-Mrs Bryant
-Mrs Bryant
Same thing happened to my '04 in July. Took it to my trusted mechanic and he said the timing chain had jumped a tooth and was throwing everything off. He said I could just replace the chain and tensioners, but recommended the cams as well. I took it to the local Ford dealership here and they told me the motor needed replaced there was no way around it. Of course I went with my mechanic, and had them replace everything. It cost me $2,475.31 and the truck runs fantastic now. Before having all the work done I asked how long I could go before it needed to be done (I was heading out of town for work) and he said he wouldn't let it go more than a week. I'm not sure what would happen if you let it go, I was too scared to try haha
-Mrs Bryant
-Mrs Bryant
There is years of reading material all over the net on this. Just search 👍
