PDA
View Full Version : 2004 - 2008 F-150
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219
  1. 2006 F150 5.4 Engine light flashing.... no codes
  2. can the truck flip while doing donuts?
  3. winter project: raptor front bumper fit
  4. High Idle After TB & MAF Cleaning
  5. Winch, Mount, lights done... Kind of...
  6. 2" BORA Wheel Adapters Installed
  7. Spark Plug Recommendation
  8. sorry for screwups on posts
  9. aaa
  10. pics
  11. Test
  12. Leveled truck hitting bumps hard
  13. spark plug help!!!
  14. 2008 4.6 surge
  15. Replaced Fuel Pump Drive module, fuel gauge issues now
  16. Keyless remotes stopped working (all of them), need help
  17. New Guy
  18. Question About Shocks
  19. Front Bumper sagging! HELP!
  20. Power window/Power lock help please
  21. Front end rattle
  22. Spark Plug Removal Poll
  23. 2004 5.4 Cracked Valve Cover
  24. What surprises lurk ahead???
  25. Gremlins in electrical
  26. Rim help..
  27. interior water leak on the passenger side
  28. 2005 F-150 SuperCrew 2Wheel drive.
  29. Rear wheel well
  30. Wiring path for keypad door handle
  31. Plug Change DONE!
  32. White & Arizona Beige Rigs - Lets see em
  33. P0345 issues
  34. Who makes the tail gate panel?
  35. Few choices for tail gate cap - why?
  36. Almost 10 years later (photos)
  37. Window Regulators. Ugh...
  38. '08 Screw - Rear Door locks
  39. 0 offset wheels & 35s
  40. update on my f150 build
  41. Once upon a time...
  42. DriveShaft Upgrade
  43. Issues after plug change
  44. steering wheel controls
  45. Exhaust Manifold Job
  46. Upgrade to an '04 5.4l lariat???
  47. 2005 f150 XLT 4X4 leveling kit
  48. Cause for celebration, or let down ( spark plug question )
  49. Cooper or Good for a Year?
  50. 2006 Lariat 5.4 Fuel Consumption
  51. loud popping and light tings sounds from Cats
  52. 2004 f150
  53. questions about my 04 F150
  54. tailgate hinge noise
  55. Need help with bad stutter
  56. 08 Lariat Climate Control stopped
  57. '08 Stereo/Climate control trim
  58. Gear Alloy Blackjacks
  59. highway mpg and coolant gauge pegged
  60. 04 Violent shaking on highway
  61. Prepping for my upcoming plug change. Question about Techron.
  62. 2006 5.4l oil Gremlin
  63. 07 King Ranch F150
  64. Ordered at cowlends.com, want the cowl black again...
  65. Headight Bulb Replacement Question
  66. New member
  67. Just replaced Phasers, Need a little help.
  68. Question on dropping the gas tank
  69. how to find squeak/rattle
  70. Instrument panel jiggles when turned on
  71. Second thoughts on buying my 04 F-150??
  72. Exhaust manifold connection to catalytic converter pipe leak
  73. someone help oit of ideas
  74. EVAP system problems
  75. Intermittent HVAC blower motor
  76. Black housing headlight on eBay, trust?
  77. What is this part leaking? (pic included)
  78. Smittybuilt M1 flares
  79. Rev limiter
  80. What The .... Happened Now!?
  81. New to f150 online! And my truck!
  82. Looking for Guidance and Answers
  83. Carpet replacement
  84. Autolamp Control loose wire?
  85. 08 F150 XL - how does low tire pressure sensor work?
  86. Edge Evo
  87. Reverse lights not working, third brake light out
  88. PO345 error code and horrible noise
  89. Don't hate me for posting about spark plugs.
  90. How to repair cracked dashboard.
  91. cruise control malfunction new 04 F-150 5.4
  92. Another maybe buying new (new to me anyway) truck thread
  93. Thinking of buying a new truck
  94. Please post up pics of levelled trucks with winch bumpers / winch mounts.
  95. 4x4 quit...
  96. What would you have done differently with what you know now?
  97. Back seat backrest removal on 2005 Crew???
  98. Question for someone with a Saleen or side chevrons
  99. Replacement Battery Advise?
  100. Engine Shaking/Rough Idle after Injector cleaner?
  101. Coolant Leak from Engine Rear (2004 4.6L)
  102. Not sure where to turn- Desperate
  103. F-150 With 3 inch Leveling Kit and 35" Nitto Trail Grapplers?
  104. My mods, and lessons learned.
  105. Tailgating photos
  106. Transmission thermal bypass valve
  107. 04-08 2wd struts
  108. Keypad install question
  109. Battery going south?
  110. Vibration trouble.....
  111. Odd question about bed removal
  112. What is causing my P0302 Code??
  113. Brake Caliper help
  114. Cross country road trip on 04 with 178k
  115. F-150 Making Noise While Accelerating & Turning
  116. New belt squeals
  117. 3V Engine Oil Cooler
  118. Truck idles rough and misfires on cylinder #5
  119. troyer performance trans cooler
  120. 2006 High Pitch whine
  121. Will 89oct work for a 91oct tune? 5star Review
  122. 2004 F150 5.4 L 3v triton Rough Idle when warm
  123. Adding front bumper w/ fogs
  124. How many other long term owners?
  125. These sounds!!
  126. Reuse upper ball joint and tie rod nuts?
  127. Brakes (?) locking up - need your help - somewhat ASAP
  128. Can we install a line loc on our 2004-2008 F150?
  129. Noise from front wheel - 4X4 related - IWE solenoid already replaced
  130. Finally - good pics and new mods
  131. changing front diff oil need torque specs
  132. replace struts in the driveway?
  133. 2008 XL with 4.2L V-6 -- any concerns about this engine?
  134. Suspension clatter / rattle (?)
  135. Not a big deal,but-just reversed
  136. 2004 5.4 330 3v Engine Work
  137. Brake Lights
  138. New guy first pic of my truck
  139. 05 F150 King Ranch Engine Failsafe Mode
  140. 2008 electircal issue
  141. Warped Manifold - Replace with Headers or Manifolds?
  142. Activating Heated mirror function
  143. Opinions? Feedback?
  144. New 04 - Holes in bedliner?
  145. Max tire/wheel size on a leveled 07 fx2 screw
  146. Non-Ethanol Shell Fuel
  147. It helps electrical specialists in eFans drivers.
  148. Headlight lenses
  149. rough country 6inch lift rear block size?
  150. Problem with dome lens cover
  151. 2" vs 2.5" leveling kit
  152. A/c in the rear
  153. When do you give up?
  154. '04..hesitate to shift?
  155. 06 pats code b1600
  156. Wearing out new tires too quick need HELP!!
  157. 2006 F150 Aftermarket Headlights
  158. 46,000 miles on 05 STX SC (hate it)
  159. No 2 5.4 3 vavle motor
  160. Oil pressure gauge not sweeping when doing a gauge sweep test & runs above H or low L
  161. 05 sliding rear glass - leaking around sliding glass
  162. Warning chimes quit
  163. best tire size?
  164. Have a few codes. HELP!
  165. Fog lamp
  166. Squeaky bed or fuel filler door
  167. crankshaft and cam tools
  168. AFE SilverBullet Throttle Body Spacer 46-33002
  169. Trans Fault wont go away!!
  170. Help with Exhaust pipes
  171. Front end vibrating sometimes
  172. 2004 F150 plug change success
  173. Fabtech real block exact size?
  174. Sway bar link lasted only a few months?
  175. new tires and shocks for my 05 fx4
  176. steering leak
  177. Whine when accelerating only
  178. Got new Spark plugs today!
  179. Oil filler plug location
  180. Shuddering, Stuttering, Misfiring Issue
  181. rear end vibration/shaking
  182. Loose spot in steering wheel
  183. cleaning the intake
  184. ECM programer
  185. "Rattle Rings"
  186. Passenger power mirror
  187. Help!!!!!!!
  188. How much torque on Sway Bar Links??
  189. can i can use a alterntor off a crown vic police interceptor on my 04 f150 5.4
  190. what is the real difference between 06 T7 and 08 HS color code?
  191. Truck got some TLC today.
  192. Back in an F150 after 3 years...
  193. Heater Hoses
  194. Look at what i found
  195. 2008 f150 stx scab - driver power lock issue
  196. O/D Shudder
  197. 2006 Lariat Wheel Squeak Only In 2WD
  198. Front axle swap
  199. 2005 F150 A/C stopped working
  200. good place to get center caps?
  201. 04 f150 p0303
  202. 2008 F150 Spark Plug Change
  203. Mirror Compatibility
  204. 2004 RWD Lariat Font Suspension Torque Specs Please
  205. Got Some Cheap Items
  206. Successful spark plug removal
  207. Radiator hose clamp failure
  208. Electrical Issue. Please help
  209. LED Side Running board Lights
  210. Sway Bar End Links?
  211. Just some photos of the truck...
  212. Lariat rims in good condition, how much?
  213. Pop Hissing and Coolant Under Hood...HELP!
  214. Fuel Pump?? FPDM?? Something else??
  215. Needing help if anyone can on 04 f150
  216. GPS Tracking Systems
  217. HELP.....changing 4x4 vaccum lines
  218. 2008 FX4 "Flareside Raptor" Build Thread
  219. Changed the spark plugs
  220. Modifications
  221. Headlight Hazing
  222. Custom Center Console Design and Build
  223. Tiregate VT
  224. Price quote for suspension&front end
  225. advice for suggested maintenance
  226. Fuel pump relay 06 f150 XL 4.2 V6
  227. Back in a truck...
  228. Click when braking
  229. jack lift or high lift?
  230. Wheels & Tires
  231. My Option of Lights
  232. I Wrote a Long and Heartfelt Post
  233. General Electrical question (pun not intended)
  234. Domelight wiring diagram
  235. pop quiz
  236. 2005 5.4l lacking power
  237. Air Leak Somewhere
  238. 2006 F150 Daytime Running Lights
  239. Pro Comp SS Prorunner
  240. Re-gearing question.
  241. F150 6 in height
  242. Oil Leak Passenger Side
  243. 6" rough country lift
  244. 0 to 60 F150 2008 5.4 "5star/AFE Combo" 0 to 70mph
  245. 2004 F150 FX4 5.4 3v Misfire issues.
  246. Magnaflow help!!
  247. All idler pulley sizes needed!!
  248. Lights
  249. 2008 F150 5.4 5star tune + AFE intake combo Review
  250. rim help
